GE 60 Cams on a 2.2T
Anybody know if I am likely to have enough piston to valve clearance with a set of GE 60 cams on a 2.2T motor?
Rob
Old 07-15-2013, 01:16 PM
Rob,
T engines have cast pistons and shouldn't be revved beyond 6600 RPM for reliability.
You don't quite have the valve clearance and I'd not machine the current pockets any further.
If you want to use GE-60 cams, I would use either Mahle 2.2S P/C's or Nickies, to suit. You will also need "S"-spec heads, otherwise those cams are a waste.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-15-2013, 06:04 PM
3 restos WIP = psycho
kenikh's Avatar
You need waaaaay more compression, to boot. That much overlap wants 10+ to 1.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-15-2013, 06:41 PM
What he said,....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 07-15-2013, 08:12 PM
