Exclamation paint heat
im painting my car and would like to colour match the valve covers. will the base clear im painting my car with work or will it bubble and peel from the heat?
Old 05-21-2013, 03:49 AM
E Sully's Avatar
Try posting in the Bodywork Forum, might get better answers.
Paint & Bodywork Discussion Forum - Pelican Parts Technical BBS
Ed
1973.5 T
Old 05-21-2013, 02:49 PM
Straight shooter
Lapkritis's Avatar
If you're going for the look then give it a shot... worst case is the paint stains/bubbles with heat and you get to do the job a second time. Not a lot of risk. I've seen a few engines all dolled up with blue paint that has turned brownish with heat. If you're interested in shedding that heat then have them blasted so they look like new and run them as bare or coat with a flat carbon black such as Rustoleum Chalk Board. Most engine paints are insulators rather than dispersants so beware on an air-cooled engine of such "engine" paints.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 05-21-2013, 04:39 PM
Tags
heat , paint , valve covers
