-   -   Just another 3.2 Short Stroke (http://forums.pelicanparts.com/911-engine-rebuilding-forum/752691-just-another-3-2-short-stroke.html)
dkirk 06-21-2014 10:55 AM
Henry,
Beautiful work! The attention to detail you apply to your engine builds is awe-inspiring. I'm thoroughly impressed!
White911SC 06-23-2014 07:17 AM
Henry,
Thanks for your clear description about the copper sealing rings. This puzzled me for awhile but I understand perfectly now. Your engine work is very impressive and I really appreciate learning from the masters on this forum.
Henry Schmidt 06-17-2015 05:40 AM
A different question (about heads and porting) linked to this old thread.
Strangely enough, this car is back in the shop. It seems that some sort of breather catch tank is needed at higher rpm and this gem will run there.
Trackrash 06-17-2015 09:19 AM
I noticed that the engine oil cooler has a screw on fitting? Older cooler or modified?
Thanks,
Henry Schmidt 06-17-2015 09:26 AM
Thanks,
The engine was installed in a 67 SWB car so the cooler was installed to fit the chassis. It is indeed an early 911 cooler.
Trackrash 06-17-2015 11:29 AM
I am considering using the old style cooler on my 3,0 build. Is there a difference in cooling capacity? Or is it just the return tube on the bottom of the cooler that is different?
Matt Monson 07-07-2015 05:53 PM
Interesting to find this thread so near the top. I just bought a car that might have something similar. I'm going to assume that there's no way to verify anything, like cam profile, or piston choice, or even being sure of the crank without tearing down the engine?
It's a weird on. 3.2 case in a '74 chassis. Advertised as a 3.0 and on CIS with single plug. Anything I can look for with it in car to give me more ideas of what the build might be? I'll dyno the car once I get it and would like to convert it to weber Idas. But if the cams are CIS cams I might want to crack into the top end first.
Henry Schmidt 07-08-2015 07:53 AM
There are very few things you can easily do to ascertain the true specs of an engine without specialty tools. Twist it up and if you like the character it displays, you're golden.
Matt Monson 07-08-2015 09:23 AM
Thanks Henry. That's kind of what I expected but figured better to ask than assume. I've got the parts piling up to build a little 2.5 mag engine, so once that's done I could swap positions on them and take a closer look at the 3.2 with it on the bench.
