-   -   used cylinders? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/753291-used-cylinders.html)
jeffery dalcour 05-30-2013 12:58 PM
used cylinders?
I am going to look at some used 3.2 cylinders. What should I be looking for.
Jeff
Trophy 05-30-2013 01:00 PM
Look for sractches, score marks, missing cooling fins etc.
Take a bore gauge if possible, and measure for roundness, and to see if they are in spec (wear)
E Sully 05-30-2013 01:21 PM
Depends also on the pistons. Alusil pistons and Nikasil pistons cannot be mixed in the other type of cylinder. If in good shape you will still see the honing marks.
tom1394racing 05-30-2013 03:44 PM
Bring a magnet. Nikasil cylinders will attract on the inner bore surface. Alusils will be non-magnetic.
What is your plan for these 3.2 cylinders?
jeffery dalcour 05-30-2013 04:43 PM
I have a 3..0 SC that I hope to turn into a 3.2ss. A mild 3.2ss with 9.5 pistons. Im not building a race car. Maybe one day......
Jeff
tom1394racing 05-30-2013 06:37 PM
Either Alusil or Nikasil will work. You will get them re-bored to 98 mm with fresh Nikasil plating.
jeffery dalcour 06-02-2013 08:00 PM
Thanks for all the help. I bought the cylinders. There Mahle 98mm . They have no grooves or scraches but may need to be replated. I'll find someone to do an inspection that know more then I.
Jeff
