993 Piston Rings
Just curious, but do all 993 motors use the same sized piston rings? In trying to install a set of rings today on a used set of pistons, the side clearance on all the rings checked to be under spec. That poses the question if all 3.6 pistons have the same sized ring grooves?
Ernie
98 993 C2S - Arena Red/Beige
76 914/6 3.2 Conversion - Estorill Blue/Coral Red
Old 06-06-2013, 11:05 PM
Hi Ernie,
All 993 N/A engines use:
1.5mm top ring
1.75mm second ring
2.0mm oil ring package
993TT engines have a 1.75mm top ring with the others being the same.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-07-2013, 11:32 AM
