-   -   Changing engine baffles without removing oil return tubes? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/754869-changing-engine-baffles-without-removing-oil-return-tubes.html)
bodmin 06-08-2013 06:04 AM
Hi - is it possible to change the engine baffles without removing the heads, oil return tubes etc? I suspect the answer is no, but there are so many magicians on this forum I thought I would ask the question.
I have been able to remove one outer baffle without difficulty. However I have no intention of doing intrusive work on the engine (3.2). Just want to change the baffles for cosmetics.
http://forums.pelicanparts.com/uploa...1370696561.jpg
Henry Schmidt 06-08-2013 07:18 AM
Expandable oil return tubes.
