-   -   Break in oil- first 20 minutes- Brad Penn or standard non detergent (http://forums.pelicanparts.com/911-engine-rebuilding-forum/756001-break-oil-first-20-minutes-brad-penn-standard-non-detergent.html)
rkeele 01-03-2016 11:04 AM
Been using Total racing 20-50 any opinions or numbers
rkeele 01-03-2016 12:45 PM
I was told by a SC oil dist. and the latest is Diesel Oil is no longer optimal for air cooled motors , they have reformulated it for the new catalytic converters in the new diesels, also told that by 2 diff. mech. that I know.
bigred23 01-07-2016 04:31 PM
That's interesting; as I understand, the primary difference between older CI-4 vs CJ-4 oils is the ash content (which acts to obstruct diesel particulate filters). CJ-4 oils still have fairly high zinc and phosphorous levels; for example, Chevron Delo 400 LE 15W-40 (CJ-4) has ~1200 ppm P and ~1300 ppm Zn. Non-LE Delo 400 15W-40 (CI-4) has ~1400 ppm P and ~1500 ppm Zn. As Henry's comments were from a few years back, I wonder if he still goes with Delo?
rkeele 01-11-2016 09:41 PM
good question he said he uses the LE which has lower numbers, Total racing is different than non racing has more zddp from what I was told.
VFR750 01-29-2016 12:28 PM
Oil Analysis by ANA Labs.
Oil Analysis performed on oil bought in mid-late 2015
20W50 Valvoline VR-1 Conventional Racing (Silver bottle)
Zinc: 1177 ppm
Phosphorous: 1281 ppm
20W50 Castrol GTX Conventional (Yellow bottle)
Zinc: 1074 ppm
Phosphorous: 816 ppm
I thought the 20W50s were not subjected to the required drop for the SN rating. Well it turns out Castrol GTX is off my list. The 20W-50 actually tested out as only a 40W at 100C test conditions. It's really only a 20W-40....
Even VR-1 now seems a little low.
Determined 02-09-2016 04:40 PM
subscribe
Alan L 02-09-2016 10:20 PM
Originally Posted by Henry Schmidt (Post 7498604)
I understand that the Porsche world loves Brad Penn but we're seeing some of the worst results (wear) in engines that use exclusively Brad Penn. We're using Delo 400 in everything.
Henry - would the SAE 30 recommendation apply to turbo as well (930) - break-in and track use? I've got to break my engine in shortly - because the last lot of rings never seated in the deglazed bores.
New P/Cs this time round.
Alan
Damon88 02-23-2023 11:06 AM
Been searching and decide to bring this thread back to life... (without starting a debate) Interested in current thoughts on break in oil itself. I have a new complete rebuilt engine ready to start soon. Locally I can get Lucas Oil SAE 30 Break in oil. This is the Data specs. Thoughts...
http://forums.pelicanparts.com/uploa...1677179146.jpg
winders 02-23-2023 11:48 AM
I recommend Driven break-in oil. I am going to use Driven BR40 to break-in my new race engine on the dyno and then switch to Driven XP6 once broken in.
I believe Driven BR is the 30 weight version of their break-in oil.
Damon88 02-24-2023 09:43 AM
Interesting. Never heard of this brand. I will have a look and read up. Not sure if it's available locally in Canada. Cheers
winders 02-24-2023 11:28 AM
Driven is spectacular oil.....very well regarded in the racing community. Not cheap....
Jeff Alton 02-24-2023 12:30 PM
It is available... Mopac Autosupply and Lordco both carry it, though I am not sure of the availability of all different part numbers.
Cheers
OSC911 02-24-2023 02:45 PM
I’m a bit of an oil nerd. I have looked into the Driven range and it is pretty impressive. Also, available in Australia fairly readily - probably going to make the switch next oil change.
Damon88 02-24-2023 03:49 PM
Cheers
Thanks Jeff! I will go to Lodrco and inquire. Cheers !!
Emo993 03-06-2023 07:50 AM
Driven Oils, developed by Joe Gibbs Racing. Lots of Nascar titles/wins with lots of oil development. Just a great oil for our air cooled engines. Best, Mark
PeteKz 03-06-2023 06:12 PM
About 7 years ago, I was at Carlisle for a weekend Ford show. Joe Gibbs Driven had a tent set up. The presentation was given by their chief engineer (I forget his name). The main point of his presentation was to NOT use any aftermarket oil additives, and just as importantly, why. It turns out that there are several dozen different formulations of ZDDP, "zinc," or whatever name you use, as well as the other additives (detergents, friction modifiers, etc.). The oil additives have to be designed to work together, so that the one does not interfere with the other or actually cause it to precipitate out. Then you end up with less ZDDP or other additives than you started with. Therefore, don't user any oil additives. But you already knew that.
Of course, when you have access to a guy like that, you hang around after the presentation and ask more questions! It was a fascinating discussion, all the details of which I can't fully recount, but some important points: the highest pressure and wear points in an engine typically are the cam and follower contact, and the rocker to valve stem. These places have high loads that concentrate in a line or even point, with a wiping motion that tends to wipe off the oil film, so ZDDP is crucial at these points. Newer engines are designed with roller followers on the cam in order to reduce these point/line and wiping motions, because EPA regs have increased the time that emissions systems must be warrantied, and the zinc poisons catalytic converters, so in newer oils the ZDDP had to be reduced, forcing the followers to be redesigned toward with less of it.
Another important point: The break in occurs in the first 100 miles, usually much less, because engines are now manufactured to tighter tolerances, and the cylinder wall finishes are smoother, so the rings seat sooner. In addition, most new engines are now test-run on a dyno before they go in the car, so that part of break-in already occurs before a new vehicle even reaches the customer. The journal bearings (mains, rods, and cams) should not break in, because they should always be floating on an oil film. Some other parts may see high loads, such as timing gears or chains, but usually not if well-designed. Driven offers a break-in oil, but he said that for new cars and trucks it's not necessary. If you are building a racing engine with cast-iron and rougher cylinder finish or using older cams and lifters, then use it.
Well, as everyone now knows, our old air-cooled 911 engines weren't designed for low-zinc oils, so we want to find oils with high ZDDP levels. Diesel rated oils became the initial go-to oil for the older hobbyists, because diesel engines didn't have catalysts until recently, so they had higher levels of it. However, as most of you also know, in recent years, diesel engines have been fitted with catalysts and Diesel Particulate Filters (DPF), and consequently the zinc levels have been reduced somewhat. So just picking any old diesel rated oil no longer guarantees high ZDDP.
To further complicate things, the oil manufacturers change their oil formulation from time to time, and don't make widespread announcements about it. It's not a trade secret, but you have to go to their websites and look up the oils and see whether anything has changed recently.
Since that's a PITA, I've been using the Ford Motorcraft brand 15W-40 diesel oil for Powerstroke Engines. I don't have the experience that some of you do with building 911 engines for decades and seeing how long they last and what wears out, or what wears out in racing, so If you have good results with a particular oil, I won't argue. But I chose the Ford Diesel stuff because it says right on the bottle, "Contains more than 1000PPM of phosphorus (that's the P in ZDDP). Not for use in catalyst-equipped engines." Yeah, that sounds like the good stuff to me. I was using Delo for a long time, and still use it in some other old cars, and I can't say I ever had a problem with it. But the label on the bottle doesn't tell you much. So I lean towards the Ford Diesel stuff. Especially when it's on sale at Walmart!
Anyway, some things to think about when you go shopping for oil. And if in doubt, check the web site for the oil manufacturer.
