-   -   Engine Builder Advice (http://forums.pelicanparts.com/911-engine-rebuilding-forum/757996-engine-builder-advice.html)
Mitch1 06-26-2013 07:34 AM
Hi all,
First time caller, long time...well you know. I'm in the process of starting a rebuild
of my 83 911 SC. Motor is out. This started as just fixing some leaks. But, since I have it out I might as well do what I think is needed. Engine has 136k miles. Ran strong with no smoking. All heade studs intact. Has Kloberschmidt Alusil cylinders.
Trying to get some input on what I should do with cylinders. I want to reuse them. Either leave them alone with pistons removed with cylinders, (no re-ringing), or remove and have them reconditioned after being checked, by someone familiar with Sunnen honing procedure for Alusil cylinders. Or have them plated with Nikasil? Thanks. Been obsessing about this for a week or so. Need to make a decision.
billybek 06-26-2013 11:11 AM
Where are the leaks coming from?
Do you have to break the engine down to repair the leaks?
Mitch1 06-26-2013 11:40 AM
Yeah Bill, cam seals, front and rear main seals and possibly 2 case through bolts...and oil cooler.
HawgRyder 06-26-2013 11:50 AM
Old trick with airplane engines to help seal them.....
After putting the 574 or whatever sealer on the case halves...run a silk thread along the flange (leaving it stuck in the goo).
This helps to seal some cases...because the roughness of the flange can sometimes allow leaks.
Bob
billybek 06-26-2013 08:50 PM
If it was coming apart I would do the head studs. It would suck to get it back together just to find a broken stud during the first valve adjustment.
Oh, and while your in there......
