carrerarsr65
964 cams?
can i use 964 rsa cams in 3.0sc hot rod engine build i have 40webers, in waynes engine book pg.113 hi performance engine calls for s cams is there a big diff.i see rsa cams for a pair pretty cheap!
Old 06-27-2013, 06:07 AM
fred cook's Avatar
964 cams
I am just finishing up a 3.3SS built on an SC 3.0 liter block. I have 10:1 Mahle pistons (100mm bore), Carrera heads and of course, the 964 cams. Even with the slightly bumped compression ratio, there is no interference using these camshafts. You will need to cut off the extension on one of the cams that was used for the camshaft positioning hardware. With the valve adjusted to 0.1mm clearance, I set the cam timing at 1.26mm. Hope this helps.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 06-27-2013, 07:05 PM
Air Medal or two
afterburn 549's Avatar
They will work.But AFAIK you want something more racier then those (964) They were made for old style fuel inject and the air plate can not satnd very much over lap in the cam shaft s
So......You could get away with something much more better !
Also if you are bumping the C/R you will want to move Hp up RPM dial a bit . JMO
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 06-28-2013, 06:06 AM
