final build advice
Getting ready to put it back together.
2.4 E engine with new JE pistons. 1. Do I need to replace the flywheel bolts? 2. I bought new rod bolts, do I also need new rod nuts? 3. Should I replace the fly wheel pulley with a bigger one to get more cooling...it does tend to run hot in the summer in traffic 4. Any other details or tricks to the trade I should be aware of. Many Thanks Chris 73 911 E |
I'm not afraid to re-use flywheel bolts, but others will disagree. They should be at least inspected, make sure the heads where the star bit goes isn't stripping. Old rod nuts are fine if in good shape. I would not use a bigger pulley for the fan system, but you could use a front oil cooler.
See answers below in red
Thanks everyone.
To be on the safe side, going to get new flywheel bolts and new rod nuts (sounds funny;-). Likely both from Henry along with the bearings if not too outragous. Chris |
The factory flywheel bolts, in addition to being about $13 each, are single use torque-to-yield type, which means they permanently elongate when clamp load is applied.
After going through two sets of these I went with the ARP 204-2802 and am very pleased with the product, the installation instructions and the price. |
I ended up going with the ARP flywheel bolts, new crank, case savers, blueprint and balance, oil bypass mod, pressure relief kit, steel studs and Westwood Racing seal kit. Plus other machine shop details around reconditioning the rods, etc.
That should cover the bottom end. Should have case back tomorrow and pistons on Friday :-) Chris, 73 911 E |
| All times are GMT -8. The time now is 02:30 AM. |
