Did you ever find out what the problem was with the oil pressure? Interested.
1983 911 SC 2015 Volks GTI 1991 Volks GTI 2011 Nissan Juke 1992 Nissan NX 2000 |
Oil Pressure
After checking everything external to the engine, I have decided that one or more of the internal oil seals is either not installed correctly or was manufactured incorrectly. Some others have experienced the same issues and have shared their resolutions with me. I am going to pull the engine back out, tear it down again and replace the questionable seals. I have acquired a set of internal seals from a different source to use on the second rebuild. At least this time everything is clean and none of the nuts, bolts and screws will be rusted or otherwise difficult to remove! Thanks for your interest!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
It's always quicker the second time...
I really hope you get this solved. Have you by any chance talked to Chris from TurboKraft? He has mentioned this on a recent customer build. He is very knowledgable and willing to help. Good luck Fred, I am watching to see this through.
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
Let us know what you find when you tear it down. I used the gasket kit from pelican when I did mine about 6 years ago and so far it has been good.
Is the oil pressure gauge flickering at all? Did you reseal the oil pickup tube?
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
Latest update.........
I have just pulled the engine and have it back on the engine stand. Will start tearing it back down today. With a bit of luck, I will know what the problem is in a day or two! Wish me luck!
'90C4 |
Engine tear down.........
Engine is at the long block stage now. Will probably do some more disassembly after supper. Hope to have it all apart by end of day tomorrow. It's a lot nicer getting to work with clean/new parts!
Subscribed, this thread is a tribute to your patient troubleshooting and this forum's group think and support.
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
Almost there!
I have everything removed and am ready to split the block (again!). I should get that done either tonight or in the morning. A few chores got in the way of doing the split this afternoon (as usual !). Will soon know if one or more of the block seals did not seat properly!
Straight shooter
Good luck - this far back in I hope you find one pinched so the mystery is solved.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Excellent progress.
Looking forward to hearing what you find.
good luck! Hope you find the malfunction!
76' 911s Signature Edition |
Found the source of the oil pressure problem
Finally got the block split and right away saw what was causing the oil pressure problem. One of the oil pump seals (on the pressure side) did not seat properly when I put the block halves together and a large piece got bitten out of the seal. Actually, I am pretty amazed that the engine had as much oil pressure as it did! When I separated the block halves, I used my engine hoist to carefully lift the left side of the block so that I could see if any of the seals were not seated properly. Much easier to lift with the hoist than by arm and back muscles! The other good news is that everything inside appears to have been getting oiled! Now all I have to do is "Reassemble in reverse order".
Sorry you had to go through all that, but glad you found a cause.
Kinsley 1980 SC Targa - MS2, EDIS |
Good to hear. At least you found it before any damage was done.
Ed 1973.5 T |
Straight shooter
Nice find, good catch with a proper trouble shooting approach.
I am very happy to hear, you found the culprit.
Thanks for closing the loop!
Will you do anything different during assembly this time to avoid a repeat?
'90C4 |
