One thing that is different these days is the Glyco main bearing shells are .0005 thinner than they were in 2013, or in 1987 for that matter. So an additional .001 clearance for all the mains if nothing else is changed - this will eat some oil pressure when hot. Did you measure shell thickness, or better yet, bearing clearance?
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Videos
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
After the next project
Thanks Fred.. I was curious specifically when you were test driving did the pressure go up that much which looks almost normal (like mine) or only at idle you had an issue? Any other RPM the idle my pressure is fine. Also, the light isn't coming on even when very low which I read somewhere it comes on around .5 bar.. Mine isn't even flickering.
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel |
Burgermeister, I agree and I bet that is the actual cause as the bearings from other manufactures are typically .0002 (2 10ths of a thousandth's) off what Porsche makes so they can keep from getting sued. With that total being .0004 (4 10ths of a thousand) it allows a little more through which would lower the pressure at idle.
In addition I had the oil modification done through Armando at CCR so my #2 and #5 get full oil pressure unlike before. I don't think that would cause any additional pressure to be lost at the sending unit but it's something I've thought about during this scenario. Appreciate the feedback!
X98 your engine looks super clean. Are you still running break in oil, or are the hot oil pressures you’re posting based on a 20/50?
Ken 1986 930 2016 R1200RS |
Ken, thank you! Yes, still running a 30W non-detergent motor oil.
Cold/Hot oil pressure
x98, I am currently rebuilding a 3.6, and I didn't make the .0005 number up. The new Glyco main bearing shells, made in Poland, measured exactly .0005 thinner than the original shells that came out of the engine. Consequently, bearing clearances are up .001, and thus 6 out of the 7 mains would be out of spec. Still figuring out how to fix that...
I measured original shells from my 3.2 rebuild from 2011 or 2012, they are also .0005 thicker than the current Glyco shells. Didn't have a bore gage back then, but I did compare shells as a sanity check, and the new Glycos from 2012 measured the same as the shells that came out of the engine. I have no idea how an extra .001 would affect oil pressure other than same or lower. The 3.6 had fine oil pressure before I took it apart. Rod clearances were .002-ish, mains were right around .0028 (the upper limit of the spec) with one outlier at .0036 and one at .0012. Probably not useful data at this point, but if you ever take it apart again, there is something to compare to. If you are still using 30W, your oil pressure will be off a bit at idle when the oil gets warm.
Burger, thank you thats great info. We shall see what happens.
I did drain the oil to inspect and put back in another round of 30 W break in oil to check the oil through a screen and check magnetic plugs... all was good. Other than light feather dust from normal break in wear there wasn't anything alarming, not that I expected there to be but still wanted to be sure or who knows, maybe a part of that seal would've come out.. worth a shot to look I guess when everything was hot.
If the sender unit is correctly matched it could be a bad gauge unit.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
