-   -   Correct oil lines with European headers (http://forums.pelicanparts.com/911-engine-rebuilding-forum/761886-correct-oil-lines-european-headers.html)
jomalkay 07-19-2013 11:55 AM
Help - Correct oil lines with European headers
Need some help, close to finishing motor build, have a set of George's European headers installed. I ordered the "standard" backdate oil lines from host, p/n 911 107 739 10 - cross over pipe and 911 107 729 10 - engine to thermostat line. The cross over line will not fit / clear this style header, looking for help on what line would do the trick and a source. Thanks, John
http://forums.pelicanparts.com/uploa...1374263702.jpg
BoxsterGT 07-20-2013 08:45 AM
I make a "cross over" hose that will work..............
http://forums.pelicanparts.com/uploa...1374338414.jpg
http://forums.pelicanparts.com/uploa...1374338471.jpg
It is similar to the factory hose for 70-71 911s but in 30mm for the later models. It connects to the 911 107 729 10 Hose that goes to the thermostat assy.
Please email me for details.
Len
