Upgrade rod bolts?
Looks like I will have to go back into my freshly built 3.3SS engine to replace the oil pump and pump to block seals due to one or more of them being incorrectly manufactured. When I built the engine, I used a new set of standard 3.0 L (10mm) rod bolts. While I'm in there, should I spend the $$$ to replace the new stock rod bolts with a set of ARP bolts? Keep in mind that this will be an engine that will be limited to 7,000 rpms as I am using the CIS system. I know that the ARP bolts are superior to the stock ones, but will the engine speeds expected stress the stock bolts excessively?
What say ye? Thks, |
Fred...all a matter of insurance.
How much is a complete rebuild worth? Compare that to the peace of mind you will have with a set of known very good hardware inside. Your choice...like the old commercial said..."you can pay me now...or pay me later". Bob |
If you are already inside the case I would swap them out....cheap peace of mind
It's not just that ARP bolts are stronger, your stock bolts are torque to yield which means that they can only be used once as they are now permanently deformed.
andy |
Stock rod bolts.....
Yes, do it.
Fred,
7000 RPM sounds ok on the stock bolts until a missed gear change hits second not fourth. Yes a small fraction of the total. |
Arp
You will need to resize the big end housing bore when you change bolts with a different tq. value, figure on avg. 40.00 per rod plus bolts
Mike Bruns |
Personally, wouldn't worry about the stock 3.0L rod bolts. It has probably happened but I've never heard of a stock 3.0L rod bolt failing. Compare the price/availability of used 3.0L and 3.2L cranks sometime . Hint, a good used 3.2L crank is a lot rarer... Unless you are a gifted driver, it's pretty easy to miss a shift with a 915 transmission. If you are concerned about damage from a missed shift (I would be), double check your piston to valve clearance and use a stiffer valve spring. The stiffer spring will cost a tiny bit of horsepower but it can make the difference between saying "oops!" on an overrev and cutting your track day short with bent valves. |
Food for thought!
Thanks, all. Lots of wisdom shared here! I appreciate everyone's input.
Just curious but what brand of main bearings are you using?
I'd save some money and get the genuine ones. :) |
Bearings.........
While you are in there, I'd remove all of the main bearings and carefully inspect them for any manufacturing flaws. If you have the means to measure them I'd do that as well.
When you get the genuine ones, you can see where each one is measured for thickness. Here is a picture of a glyco bearing with a manufacturing defect in the back if the shell. Ive also seen where the bearings have what looks like a "paint drip" for lack of a better term on the back of the bearing shells. http://forums.pelicanparts.com/uploa...1374590238.jpg |
as far as resizing the rod ends when you swap bolts. Measure first. they might be fine. mine were ok i plastigauged all of them and they were perfect. if they end up too tight then get them resized.
| All times are GMT -8. The time now is 11:07 PM. |
