3.6 Deck Heights
I'm in the process of rebuilding my 3.6 motor. I'm at the point of determining the deck heights of each piston. In so doing, I have determined that my deck heights are in the range of 1.10 to 1.2 mm. I used a dial indicator to determine TDC on each piston, and then used a caliper to determine the deck heights. I took four readings on each piston at the 12, 3, 6, and 9 o'clock positions on each piston. In general, the deck heights were in a rather narrow band,between about 1.1 to 1.2 mm. Wayne suggests that 1.25 to 1.50 mm is the acceptable range for smaller engines. Lacking any specs on what is acceptable for a 3.6 motor, am I OK with this clearance? And, what are my options if this clearance is insufficient?
Ernie
98 993 C2S - Arena Red/Beige
76 914/6 3.2 Conversion - Estorill Blue/Coral Red
Old 08-02-2013, 04:00 PM
Hi Ernie,
You are good to go.
I like to see 1mm (.040) deck height as anything over 1.3mm can make an engine more prone to detonate.
Hope this helps,
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-02-2013, 04:41 PM
Originally Posted by Steve@Rennsport View Post
Hi Ernie,
You are good to go.
Hope this helps,
Thanks Steve. Sounds like I am OK then. I'll start to assemble the heads and cam towers this weekend. Hope to have this motor done in the next two months! Thanks for all your help.
Ernie
Old 08-02-2013, 04:46 PM
