extra part - whats this for?
So there is an extra seal in my kit. Looks like the seal that goes behind the cam covers but I am positive I installed two. Did I miss somthing?
Thanks, Chris 73 911 E http://forums.pelicanparts.com/uploa...1375580570.jpg |
The only other O ring that looks like that is the #8 nose bearing O ring. If I were a nicer guy I'd dig one out and measure it, but I'm not.
I definitly have the#8 bearing gasket on there and this is bigger. Thank god it is not somthing that should be in the case. I think my gasket set came with an extra cam cover gasket.
Could be complete tomorrowhttp://forums.pelicanparts.com/uploa...1375590388.jpg |
The seal kit covers a lot of engines, for some the is quite a few seals left over...
If your confident that you haven't forgotten something, trust your gut. |
930 intercooler intake seal.
Thats great news. Its almost ogether, the end is in sight. Would not be happy if I had to take it down to the case again. Its been a longer then expected project with a few set backs along the way.
I dropped one of the cylinders and it cracked $500 mistake One of the pistons ring lands was broken $1000 for new ones Machine shop installed the case savers 2 mm shallow so spent $200 on 996 head bolts which are slightly longer Dont see any more set backs on the horizon and the hard parts are done :-) Chris 73911 E |
Goes under the throttle body if its the same as the seal behind the cam gear.
Bruce |
Looks nice... shiny
almost done. last part arrives today...engine / trans stud.
Chris 73911 E |
This looks like a camshaft plate o-ring. I also got an extra one in my seal kit.
Nice picture man ! good luck
| All times are GMT -8. The time now is 04:24 PM. |
