I've been using the Dow 55 and have been very pleased with its performance.
From past experience, I've learned to take these things with the proverbial grain of salt. When my name and reputation is on the line, I tend to stick with what I know works. When I don't know, I RESPECT the opinions of the professionals who have more experience than I do. Especially the ones where the pride in their work is easily evident. Experience is an expensive lesson and I value that. What is written on paper sometimes doesn't clearly make sense as to what works in the real world. The Dow 55 my reduce the tensile psi as per the posted chart but personally, I can't say I have seen or heard of anyone having a problem with it. In fact, I've noticed that some o-ring seals seem to last longer than before. That is my personal "real world experience" with it. The Dupont grease seems like good stuff. Maybe it's a great alternative for engine o-rings and seals. But if you try and get this point across by contradicting the positive experiences everyone has already had (for quite some time now) with the Dow 55; you might have a hard time getting people to take the advice seriously. No one wants to listen to "snake oil salesman tactics." I personally don't think anyone has anything to worry about their dow 55'd o-rings in their engines. |
Share your half of the conversation if you want to air the dirty laundry. Otherwise remove the inflammatory post.
Thank you, |
The first post in this thread actually is a good example. Given the DC 55 is presented as the best and the supertech fan club jumping in to blame the chamfer instead, one can only wonder how many are out there.[/QUOTE] I don't think anyone is holding anyone "beyond reproach." I think people are getting good advice from professionals who have everything to loose if they gave out advice they didn't believe in. People pick who they ask for advice from who they believe is the most qualified. End of story. I had to chamfer the holes in my own engine and without any previous knowledge that supertech recommended it. It seems as if the chamfer is a simple design flaw that experienced people have been able to properly identify and improve. I don't see how any grease can overcome a mechanical shortcoming. |
And here's the graph from manufacturer showing the loss of strength going from ~1250PSI to ~700PSI when using DC 55:
http://i458.photobucket.com/albums/q...ps13839b78.jpg That's about all I have to share information wise. The last nugget of info on this topic... Lindy, let's wrap up our business in private message where it belongs instead of spoiling the public thread. |
The mystery is solved.
After spending nearly an hour on the phone with Bob Nelson, products application engineer for Dow Corning Corp., we now have the definitive answer to Dow 55 Molycote and Viton compatibility. Bob says that the tensile strength reduction is part of the product design. Dow 55 has a proprietary agent that swells the o-ring after installation. This swelling reduces tensile strength and reduces compression set while increasing seal surface pressure. Compression set is the o-rings ability to maintain its shape during prolonged cycles of compression and relaxation. The lower the number the better the seal. Dow 55 (in all its formulas) accomplishes this process with no measurable deterioration to the o-ring. He also noted that Dow 55 offers no capillary action (wicking) with regards to most engine lubricants (additives may vary its resistance) unlike the use of white grease in similar applications. Given this new found explanation, it appears that Dow55 is the perfect compliment to Viton under our application. Late information: My earlier conversation with Bob was just confirmed via email from Dave Kraycsir that Dow 55 is compatible with all formulas of Viton but especially Viton A . Dave Kraycsir - Technical Customer Service Sr. Engineering Specialist Dow Corning Corporation |
In the end, I guess, it all adds up to how much tensile strength is required for the O-ring to do it's job and if Dow 55 reduces that level of strength to the point of failure. Evidently there is sufficient strength of the Viton O-ring, even when compromised by the use of Dow 55, for it to do it's job over the long haul. I would think that compression set (as you mention) would be critical to sealing around threads of a case bolt where the O-ring is distorted around the threads for an extended period of time.
Thanks Hank, OOPS; I'm mean Henry! |
Yep, never doubted they would recommend it as stated in my previous post. Just the tensile strength issue when alternatives exist that don't have that negative effect.
BTW, what is the molykote reference in your conversation with Dow about? I thought we weren't talking about the molykote line per your previous posts. |
Most of the post speaks to Dow55 in general. My evidence for this is the statement "Dow 55 (in all its formulas) accomplishes this process with no measurable deterioration to the o-ring.". I've highlighted the important information for you. It should be obvious to all that, lubricant, beveled holes and tensile strength is not what this is about for little Raggedy Andy. What we have here is a want-a-be trying to stroke his ego by attacking the knowledge and experience of a consummate professional. It’s a sad but common story in every profession. Monday morning quarterbacking. Now from Andy, we're getting :" two experts at Dow lied", "an independent consultant PSP INC. lied" and "Henry's experience is a lie". What a friggen joke!!! |
Enough is enough. Sorry OP, our forum wasn't always like this.
| All times are GMT -8. The time now is 09:39 AM. |
