so close yet so far
f ing disaster. I am putting the distributor on my nearly completed 2.4 and I push too hard and the f ing top bolt in the engine stand pulls from the case. The bottom bolt bends then snaps leaving my engine on the tray a foot from where it had been seconds earlier.
I think the engine is OK. I need to fix the two bolts. Both will need new threads. So how do I do this? The top bolt came out with a helicoil on it so the hole is pretty big. Is there a case saver type option for bolts this size? I assume I need a fix with long threads (that go deep into the case as these are big bolts) Whats my best option? Thanks, Chris 73 911 E |
Sorry to hear that.
I hope that your engine id fine apart from the studs. Did you use the proper engine stand/adapter? |
Yes, I am using the porsche yolk. Totally my stupid fault. What was I thinking. I should have put the distributor in when the engine was in the car. Of course this was going to happen if I push on the end of the engine. It's only held on by two bolts.
Moving on....need to fix it. Chris |
Time sert or other type of thread repair could work.
It might be inappropriate but this is where I get my timecerts
Mechanics tools and bits 365 Hemlock lane Nazareth, Pennsylvania 18064 USA Phone: (877) 746-4682 Web Site: Mechanics Tools and Bits - Wholesale Tools - Home of the Thread Doctor EBAY SALES Bruce _________________________________________ |
I have rebuilt a motor that suffered a similiar failure. The solution a previous spanner jockey had used was very elegant. They /He /She had drilled out and tapped the case where the m10 studs had pulled to m12 the made inserts with m12 outside and m10 inside . These had been fitted to the case with studlock.
Admittedly the insert was thin on its walls but it had lasted well. Very like using a time sert or case saver to be honest but a home made solution |
just ordered a kit from Time Sert.
the 5015 F Big-Sert kit 10X1.5X20 Big-Serts and everything to install them. Just hope I don't f it up like I usualy do when trying to do these thread inserts. Chris 73 911 E |
Can someone tell me the bolts I need
The two pictured (mating my 2.4 to a 915 trans. Plus one of the two studs on the bottom front of the engine (one bent). Can I order these from Pelican? Chris 73 911 E |
Try this number
999.062.192.02 Stud bm 10x102 not for sportomatic Bruce |
Patrick Motor Sport is the jackpot. They have a kit that includes all studs $40
Big Sert installed...some beefy threads on there...extra strength!http://forums.pelicanparts.com/uploa...1375965530.jpg |
| All times are GMT -8. The time now is 08:57 AM. |
