-   -   Need intake valve overlap for 2.4 case. 2.2e pistons and 911e cam???? Help? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/765218-need-intake-valve-overlap-2-4-case-2-2e-pistons-911e-cam-help.html)
marlinaness 08-10-2013 03:15 AM
I am using a 2.4 case, crank and rods
I am using 2.2e pistons and e cam (same for 2.2 or 2.4)
911e cam was for fuel injection. I am using Webers.
Wayne's book says the intake valve overlap for the 2.2e is 3.0-3.3 and intake opens 29 degrees BTDC
Waynes's book says the intake valve overlap for the 2.4e is 2.7-3.1 and intake opens 18 degrees BTDC
Interestingly the 1967 911S with Webers has just a tiny bit more lift than this e cam, has overlap of 5-5.4, and opens at 38 BTDC.
so with nominally 9.5 or so compression with this combination, should I go closer to the 2.2 e as it is closer to the 911S with Webers.
Subject to experts saying I am wrong, I am going with the 911 2.2e.
Recommendations for this novice?
larrym 08-10-2013 08:06 PM
use the E spec - going more advanced will get you a lot of backfiring and reversion in the carbs - (BTDT) - and poor street torque - the S spec will get you high rpm and no torque below 3000-3500 - that's great if all you plan to do is go racing and never run under 5000 rpm
marlinaness 08-11-2013 03:50 AM
so, sounds like 2.2 e spec is the better option. The only good point for arguing is that the 67 S had webers and had a lot more advance compared to the two e specs which were fuel injected. Maybe it takes the carbs longer to move the fuel.
Nevertheless the 2.2e should be safe from a piston valve collision problem since it was "generally approved".
thanks
Marlin
