-   -   2.7 lt Engine case (http://forums.pelicanparts.com/911-engine-rebuilding-forum/766434-2-7-lt-engine-case.html)
wareen 08-16-2013 05:31 PM
2.7 lt Engine case
Does anyone know the original width of the 2.7lt case or half case when measured through the case through bolt, hole. Maybe around the 107mm plus?
356RS 08-17-2013 10:05 AM
213.5mm from through bolt seat to through bolt seat.
wareen 08-19-2013 11:17 PM
Mark,
Has the bolt sealing face been machined on your case as mine would have approx 1mm machined off and the case thickness now measures 107.1 and 106.7.
I should have measured it before machining.
thanks
francis
356RS 08-21-2013 08:43 AM
No it has never been machined as far as I know.
