-   -   3 pin CD Question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/766641-3-pin-cd-question.html)
Rslevin 08-18-2013 12:20 PM
3 pin CD Question
I have a '73 911 and getting no spark. CD is humming and wiring seems to be correct. I am getting no voltage on terminal A, 15 on the coil from A terminal from the CD box. Shouldn't this be at 12V? Thanks for any help.
Flat6pac 08-19-2013 04:27 AM
The wiring is getting old. The core wire with the white cover , surrounded in steel ground cover. is breaking down and if you meter the wires you might find the white wire is common to ground.
Bruce
Rslevin 08-19-2013 11:31 AM
I thought that was a ground. I have 2 grounds running from the D terminal on the CD box. One goes to the distributor body, the other the coil ground. I am not seeing a white wire, nor any reference to that in the wiring diagram. Can you be more specific as to where this wire is and what to do about it? Thanks,
E Sully 08-19-2013 02:49 PM
You will not get a voltage reading on the A terminal. The B terminal should have the 12+V reading. If it is whining, then the 12V is there.
If you have the original CDI wire harness, the A and C wires are white with gray exterior over the shielded wires. B is Red.
The 2 shielded wires combine the shield at the CDI with a common connector to the ground tab. Heat shrink is used to cover the shield.
Here is how I test the CDI. I connect a spark plug lead to the coil, Instead of using the points, I touch the C wire to the ground tab on the CDI to get a spark. Second picture is a CDI harness timmy2 is making up for a replacement harness, using white exterior instead of Gray.
A CDI can whine and still not work.
http://forums.pelicanparts.com/uploa...1376947891.jpg
http://forums.pelicanparts.com/uploa...1376948158.jpg
Rslevin 08-19-2013 03:13 PM
Thanks for that info. To be clear, of the two braided shield wires, one goes to the coil minus, the other the the distributor body? I did Ohm out the shielded wires from the ground to both the Coil A and the points and neither was grounded. I'll check the CD as you described. Thanks again, Rich
