-   -   throttle bobys (http://forums.pelicanparts.com/911-engine-rebuilding-forum/766779-throttle-bobys.html)
lucas911 08-19-2013 08:07 AM
throttle bobys
Hi
what is the best way/option to go if i want to put individual throttle body's on my 911sc?
jsveb 08-19-2013 08:14 AM
Search the forum ( itb) there are plenty to choose from.
Good luck
Trophy 08-19-2013 08:19 AM
"throttle bobys"
Are they the English version?
Lots of Options out there:
PMO
Jenvey
Hargett Precision
Other that make kits using mainly Jenvey ITB's"
Rothsport
9M
lucas911 08-19-2013 12:01 PM
HeHe!
sorry i ment ''throttle body''
will have a look at above mentioned options and give an update
lucas911 08-19-2013 12:07 PM
throttle bodys aint cheap! but so nice
Trophy 08-19-2013 02:04 PM
Rothsport make a great setup that is designed for the 911 spec series which I believe is based on SC engines. The only problem they are very expensive and of course you also need an aftermarket ECU to make it all work.
roblav 08-19-2013 04:25 PM
2001 (or so) Suzuki GSX-R750 individual units. Set of 4 for $100. So need to buy 2 sets. 42mm inner diameter at throttle plate. Takes a bit of effort to convert but they are very cheap, very light, and very effective.
lucas911 08-20-2013 01:18 PM
Will have a look at Rothsport and see what direction to go! I have a nice aftermarket ECU system,
So I am 1 step closer
lucas911 08-20-2013 01:19 PM
Will also check out the GSXR ones out! Will give an update if I find something
Spenny_b 08-20-2013 01:35 PM
Triumph Triple itb's ;) ...less wastage, lol
lucas911 08-25-2013 12:24 AM
I find the perfect throttle body package! And it includes the ECU system and easy to install!
Will update with pic when I received it,TROPHY you will like it
jsveb 08-25-2013 08:02 AM
Dzug???
Trophy 08-25-2013 12:46 PM
Do Tell....
lucas911 08-26-2013 01:31 PM
http://forums.pelicanparts.com/uploa...1377549083.jpg
lucas911 08-26-2013 01:32 PM
Almost done!
Trophy 08-26-2013 01:35 PM
That looks great, who makes it?
porterdog 08-26-2013 08:55 PM
Yeah, come on- tell us something good! :)
lucas911 08-26-2013 09:21 PM
Will give all detail on everything soon,just want to fit filters and dyno
Jeff Alton 08-27-2013 06:03 PM
We have used Jenvey and PMO.
Jenvey have a straight intake manifold, PMO uses a Weber style intake.
Jenvey a pain to balance, PMO easy as pie.
Jenvey requires some adaptation as they were designed for a cable throttle, but it is easy to configure a rod set up or spend $$$$ on the Rothsport linkage.
We seem to make more power with the Jenveys...
PMO have the classic weber look....
I have another set at the shop I will post pics of because I can't tell who made them. They are interesting but have a rather oddball linkage set up that will need some work. We plan to use them on a 2.8....
Cheers
SchnellSchweitz 08-27-2013 06:44 PM
Boy would I like to throttle these boobies.:D
http://forums.pelicanparts.com/uploa...1377654205.jpg
Sorry... I just couldn't resist.
PFM 08-27-2013 10:19 PM
Well oiled they are....
lucas911 08-28-2013 12:07 PM
I will take 2 sets pls asap!
lucas911 08-28-2013 12:08 PM
Will take 2sets asap!
lucas911 08-28-2013 12:10 PM
http://forums.pelicanparts.com/uploa...1377717045.jpg
Trophy 08-28-2013 03:06 PM
Ok, it must be time to give up the details.....
And I would take 2 sets of the Oiled Bodies, however, I am sure my heart would only handle a Single TB :)
lucas911 09-04-2013 11:11 AM
http://forums.pelicanparts.com/uploa...1378317952.jpg
http://forums.pelicanparts.com/uploa...1378318276.jpg
lucas911 09-04-2013 11:12 AM
Its a live!
lucas911 09-04-2013 11:24 AM
I fitted the throttle bodys and new links,took it today for a test drive! You could feel the difference from the start and sounds excellent and throttle response also good.hopefully take it next week for dyna
Unobtainium 09-04-2013 10:28 PM
They appear similar to the custom billet ITBs made by Bob Holcombe @ MODE
porterdog 09-05-2013 05:44 AM
Quit teasing and tell us about them, please.
JmuRiz 09-05-2013 07:54 AM
No joke, this is getting ridiculous...
safe 09-05-2013 01:05 PM
What ??
I'm still staring at the picture on the first page imagining heaven.....
Trophy 09-25-2013 11:42 AM
I think it is about time you gave us some details on these bad boys!!!
al lkosmal 09-28-2013 10:13 PM
Very sanitary install, especially for a newbie, but this is beginning to feel like a build up to a commercial.
regards,
Al
3literpwr 09-29-2013 08:45 AM
So what are these? Im in the market for my rally build....
LP
3literpwr 10-20-2013 02:44 PM
Lucas911 do you have any additional info to share about this setup? Anyone else find out what these are?
mreid 10-20-2013 04:47 PM
Ironic that the tuned boobies were posted by a guy from Beaverton!
I have PMOs on the 3.6 in my 1984.
http://img.photobucket.com/albums/v6...ps4753a304.jpg
sc_rufctr 10-20-2013 06:59 PM
Same girl... Photo-shopped ;)
