Interesting video - 911 head resurfacing
All,
I am preparing to complete a top-end rebuild due to a broken head stud on my 80 911SC. Will post here when I get started :cool: I anticipate that the heads will need to be resurfaced - found this related video that may be of interest: Resurfaceing the Porsche 911 Cylinder Head - YouTube Safe and Happy Motoring, Tom |
It's funny you have both of those videos posted.
After I saw "fiatnutz" youtube clip, I asked Gord of "GordsGarage" if this was something he could do. As you can see from his blog, he accepted my challenge. I am very happy with the machining he did. In addition to resurfacing the heads, he also cut down and pressed in my new valve guides. I did the easy part of removing the old valve guides and left the hard work for Gord. Once he installed the new guides, I used a hand cutter and quickly re-cut the valve seats. I'm hoping to get my butt over to his place sometime in the next month to bead blast and powder coat all my engine tin. Once I get the engine back together, I plan to pull the motor from my other '73 and get him to do the same head work, hope he's still up for it. |
jrbennett, if you don't mind me asking, how did you size your guides to the valves? Did you hone them or ream them? I'm wondering if this is a diy job or if you had to have it done.
thanks for any info. |
Note that in John Edward's video he used a piece of an old cam housing as a way to make an adapter/fixture to hold the head in the lathe chuck. I've got quite a few junk housings if he (or anybody else) would like a housing to make a head fixture.
I would use the old cam tower method. You would get much better precision and repeatability if you mounted a modified cam tower to a face or fixture plate that attaches directly to the spindle.
.003 run out on a 3 jaw chuck is considered "good." |
I removed the valve guides by threading a bolt into the guide as found here in Henry Schmidt's post http://forums.pelicanparts.com/911-engine-rebuilding-forum/552404-valve-guide-removal.html#post6506422 Gord machined the outside of the guides and pressed them into the heads (we tried 2 of each brand). He preferred the Canyon ones because they start with a thiner outside diameter and there is already a step on the outside for setting the installed depth. I then used a reamer to clean the inside of the guides and fit the valves. I also preferred the Canyon brand guides. The Porsche guides required quite a bit of reaming to install the valves. The Canyon ones basically needed a quick pass with a reamer to ensure smooth install. So the 2 new Porsche guides were removed and we used the Canyon ones. Reaming the guides and a quick re-cut of the seats was easy enough to DIY. I don't have the equipment nor the skills to size the outside of the valve guide prior to installing into the head. I've seen several pictures of cracked heads from what I believe is too much interference fit, here's an example http://forums.pelicanparts.com/911-engine-rebuilding-forum/686840-head-damage-during-valve-guide-replacement.html#post6836040 |
Thanks for the great information!
Working in the film industry for Panavision for long time, I machined many different parts.
Runout on our lathe was less than .0004" (had to be for the camera and lens equipment)...so I benefitted from that when doing anything for myself. I didn't realise how lucky I was at the time...now I do. Bob |
| All times are GMT -8. The time now is 06:05 AM. |
