-   -   Bench start / hot wire engine (http://forums.pelicanparts.com/911-engine-rebuilding-forum/772683-bench-start-hot-wire-engine.html)
ppetion 09-21-2013 01:04 PM
I am tryng to bench start my 6 with carbs. I have fuel but no sparks.
I check the points and they are opening and closing. All grounds are connected. Positive is applied the positive side of the coil. The only thing I am not sure how to chck is the cd box. As far as I can tell the c box is powered from the positive side of the coil.
help!
Flat6pac 09-21-2013 01:41 PM
The 3 prong CD gets power from the center of the 3 post plug in, 12 volt. The coil and the points are fed from the other outside white wires,
Bruce
E Sully 09-21-2013 02:21 PM
You have it a little backwards. The CDI is powered by the battery, and the CDI to the coil. It will hum when 12V is applied.
http://forums.pelicanparts.com/uploa...1379798356.jpg
ppetion 09-21-2013 03:40 PM
I understand a b and c is at the plug, what is d? I don't seem to have a d, the only extra plug I have is a ground from the harness
Flat6pac 09-21-2013 04:12 PM
D is the ground tag on the bottom front as is the tag on the chain cover nut under the distributor. Your shield wire connects to the ground.
Bruce
ppetion 09-22-2013 10:27 AM
Thanks . I got it started. I didn't connect the ground on the Cdi box.
larrym 09-22-2013 10:42 AM
this is a re-post of same thread you started on another Tech forum - see the discussion there
914World.com - The fastest growing online 914 community!
