3 out of 6 cylinders do not like 12.5:1 compression
I have built a 2.4 liter 12.5:1 compression, 46 mm throttle body, DC70m cam engine. We were tuning it this weekend at Little Talladega when things started to go down hill. I checked compression at home to find 3 cylinders with 0 compression. Initial teardown indicates blown head gaskets. I was using stock head studs and stock torque requirements. Obviously this is not adequate. Where should I go from here to seal these cylinders?
high comp engine
Are the tops of the cylinders cut for head gaskets? If not, something to consider. Also, you could add a shim under each cylinder to lower compression marginally. I assume that you had measured compression on each cylinder earlier. If so, were the 3 blown cylinders higher than the other 3? Were the blown cylinders all on the same bank? Was the deck height set the same for all cylinders? All questions that should be answered before attempting to reseal the engine!
almost forgot.......
At 12.5 cr, I assume that you are using twin plug ignition. What were you using for timing advance? Also, are you certain that all plugs were firing?
The cylinders were grooved for the O ring head gaskets. I am running twin plugs with a max advance of 30 degrees. The cylinders that where blown are 3, 4, and 6. I have yet to pull the engine and the heads so more info to come.
Timing w/twin plugs.......
Check out our SafeGuard knock controller.
Too much advance for twin plug.
If you track the car, just use E85, you will make more power and engine runs much cooler, also you pretty much never encounter detonation with NA.
If it is not available, just buy a barrel of denaturated ethanol and mix 15% of regular gas into it. Here we can buy ethanol for 1.20€/litre in 200l barrels. |
I pulled the engine apart last night. No signs of detonation. But I did have 5 blown head gaskets, one so bad it burned through the steel liner. I am using birels. I checked the torque of the head studs prior to disassembly and they were all loose. I suspect the studs were loaded past the yield strength causing the blown head gaskets. I will post pictures later. |
Re: E85. Not as easy as just putting this fuel in. The lower energy potential of the fuel relative to gasoline means you need to adjust the mixture to add more fuel for the same HP output. Once you have the mixture adjusted correctly for e85 you can run more advance.
Still think it was the advance. So much advance put all the energy into lifting the heads instead of turning the crank.
http://forums.pelicanparts.com/uploa...1380894966.jpg
http://forums.pelicanparts.com/uploa...1380894991.jpg http://forums.pelicanparts.com/uploa...1380895005.jpg I have no problem backing off the timing, but I need to figure out how to keep these cylinders sealed. Do you think stock studs and torque will keep them sealed if I back off the timing? I have noticed the back two cylinders faired the worse. Is there a way to get additional cooling to the rear? I am intrigued by the E85 fuel for the cooling effect. I am running a Megasquirt 3 engine management so I can adjust for just about anything. One concern is my aluminum fuel surge tank. What will E85 do to that? Lots of questions for now |
Cylinder studs
Get hold of Henry Schmidt at Supertec. They offer a set of very high quality studs designed specifically for performance engines. He also sells a set of repro 906 air diverters to go around the cylinders. He should also be able to advise you on the best sealing process for your cylinders/heads. Nice guy and very helpful. One of the top 3-4 engine pros here on the board.
While you are in there............
Check your heads for valve leakage by closing the valves and filling the combustion chamber with ethylene glycol (antifreeze). If a valve is leaking, you will see a wet stain in the intake or exhaust ports.
Henry has already said I was nuts to try 12.5:1. He suggested 10.5:1. I was rereading some of his previous posts on the subject and I was struck by his statement that with a mag case you should try to avoid creating heat rather than trying to take the heat away after the fact. I now know what that means. I am considering dropping the compression to a more reasonable level.
On the photo of #4, 5, & 6, it looks like there was no spark plugs in the left side holes? Carbon build up in the plug holes. Right side plug holes with clean threads? Were the left side plug holes caped off? Or is this a camera angle deal? Just curious.
Camera angle. All the plugs were in place
One survived..........
The fact that one cylinder survived the ordeal indicates to me that the pressures are right on the "edge" of being too much. You could try adding a base shim on the cylinders to increase the deck height slightly and also back down the timing to around 23-25 degrees. Also, if your engine management is sophisticated enough, map cylinders 3 and 6 for a bit more fuel for cooling purposes. Might be just enough relief to let the engine survive! By the way, did you check the compression pressures in each cylinder? Also, did you CC the combustion chambers? If a couple of the heads have a bit more volume, put those two on cylinders 3 and 6. Good luck!
Neilca - how certain are you that the cylinder bases were true, that the cylinders were the same height, and that the heads were all cut to the same depth. Maybe the cylinders which did seal were a hair taller, effectively, and also prevented the right seal on the others?
Walt I checked those things prior to assembly. I have a marble table and height gauge for measuring such things. I used a straight edge on the spigots.
Scratch one theory. The head photos suggested 2 and 5 were the only ones not having problems (though 3 were worse than the 4th), which suggested some kind of height issue, as in those two had taller cylinders and held up the others. Though one would think that would show up by the cam binding as you assembled the motor. I think a lot of us have had the experience of needing to loosen the head nuts and retighten on occasion to get the cam to turn freely.
On my 2.7 race motor I ran conservative ignition advance. But on my 2.8 long stroke I see I was at 30 degrees by 3,000 rpm, 33 at 6,000, and back to 30 at 7,500. This motor I shifted at 8,200. Nominal Mahle 10.5 CR. When I pulled it down based on 125 hours the bearings looked like they could maybe go another 125, and nothing wrong with anything. No head seal issues. ARP studs. This based on what the previous owner of the motor did, and what a local shop and tuner did when we had it on his dyno. My short lived 2.8 short stroke (pulled a piston in half) had measured 12 CR. Only had chassis dyno time (<1 hr), but no signs of head seal issues using the same ignition map. Supertec studs. All these sand cast cases. Maybe a mag case is more sensitive? Certainly not as strong, but you said you checked torque before disassembly, and it was what it should be? I'd have thought that the steel studs were strong enough. The special virtues claimed for aftermarket studs is that they have thermal expansion characteristics complementary with aluminum cylinders, and don't just break like Dilivar can. They are significantly stronger, but isn't regular steel strong enough? The change to Dilivar was due to studs pulling out of mag with the Nikasil/Alusil, wasn't it? Not much has been said about expansion and Biral. The steel liner presses against the head, but nothing rests on the case at its base. The aluminum around it buts against both, so I suppose it has expansion much like the all aluminum cylinders? Just not as much force from thermal elongation because of a thinner aluminum section? You don't hear of issues with Biral like the liner getting loose from differential expansion. |
I was thinking about the birals the same way. It is odd that the compression of the head studs is transferred by shear between the steel liner and the aluminum fins. I would think the expansion would be like the steel liner which is half that of the fins. It is amazing these do not delaminate under the compressive and thermal loads.
| All times are GMT -8. The time now is 04:50 PM. |
