-   -   CX racing 3.0 connecting rods (http://forums.pelicanparts.com/911-engine-rebuilding-forum/774346-cx-racing-3-0-connecting-rods.html)
greyes59 10-01-2013 06:45 AM
anybody have experience with using CX racing RSR 3.0 connecting rods?
they are sold in ebay.
KTL 10-02-2013 11:30 AM
Made in China. Run.........
No free lunch with those rods. You're better off with original Porsche rods that you've had reconditioned. Just my opinion.
porterdog 10-03-2013 04:50 AM
That is not a place to install a component you wonder about.
greyes59 10-03-2013 04:57 AM
thanks !
Schmierung 01-31-2019 10:37 AM
I also would like to know if anyone has true experience with these in a Porsche engine?
lvporschepilot 01-31-2019 11:00 AM
I have two clients who run these in their track motors every season. I recall one of them acquired a set and a couple of the rods had to be resized out of the box, which Engine Services next to Road Atlanta did. They built the engines on their own, I just tuned/rejetted for them on the dyno. Neither have blown up, both are high revving twin plug units run very hard primarily at VIR and RA. One is a 2.5 or 2.7, the other is I want to say a 3.1L unit. I have never used them, but I know for a fact these two gentleman have and have had no issues.
Folks need to understand, Mahle themselves have it's either 13 or 14 factories......in China. So do Magnetti Marelli. Lots of OEM manufacturers have OEM parts made.....in China. Every company has some presence there for something. If ancillary parts aren't made in China, they're made in Turkey or Poland. The problem I've experienced is Chinese factories are not all equal, but the good ones produce quality that isn't all bad and can even be superior than many EU suppliers. Don't kid yourself, it's not what it was 20 years ago.
Schmierung 01-31-2019 12:19 PM
Thank you lvporschepilot. I know many Japanese based engines successfully running these.
You are spot on with Chinese manufacturing. I see this in my professional sector.
KTL 01-31-2019 12:32 PM
I totally understand that made in China = garbage is not all-encompassing and there's major corporate industry outsourcing there. But something very small niche like this, you have to be cautious.
Thus, lvporschepilot sort of proves my point. If a set of brand new performance rods needs to be resized right out of the box, that's rather telling. That said, there needs to be context behind how much out of spec were they from center-to-center to warrant the resizing.
Lastly, they're so inexpensive it's nearly impossible NOT to think "if it seems too good to be true, it probably is." Because a set of the basic H-beam rods is $319 w/out bolts and $349 with the bolts included. I'm not one to think you have to spend a ton of money on something just because these are Porsche 911s. But that price is just crazy when you consider they can't be producing a high volume of these rods whatsoever. We're not talking about Chevy LS# (pick a number) rods here!
lvporschepilot 01-31-2019 05:54 PM
Chevy LS motors or any number of far higher BHP per cylinder pushrod V8 engines are running rods very similar to these, made by Eagle or the like. Eagle and all manner of other domestic v8 high-po manufacturers have all sorts of stuff like this made in China, from bolt-on ready heads, cranks, rods, pistons. There is even a rumor that Carrillo have a blank made in China that is then machined in the US. Everyone realizes that some 95% of all aftermarket water pumps and pump bearings/seals are all made in China now right? That's how much they've taken over the market or stuff is outsourced, and I am certain most weren't aware. Thanks US labor unions.
And KTL, there is no factory in China that will do a run of just about any auto part that is under about 400, meaning I have no doubt CX racing or whoever had a short run of them made. It's not much, probably around $20-$30 or so a rod. One just has to be willing to shelf them for a while, which Porsche rods will indeed sit for a while so Porsche crowd can groan about them, until they become a fact of life like everyone else made there.
Point is, I truly doubt a 911 engine makes enough power to break one of these forged Chinese rods anyway. Same rule applies with these as goes for iron cylinders, and any good engine build. Measure measure measure, correct if necessary. I can hear the old fuddy duddies groaning now, sweet music.
KTL 02-01-2019 09:21 AM
I don't disagree with anything you're saying. You're in manufacturing, i'm not. I'm just speculating with a micron of automotive manufacturing knowledge from a few friends in the industry.
But I still think it's nuts that rods like these come along at a 1/6 of the cost we see for similar rods like Pauter or Carrillo.
I also don't disagree with you about measure measure measure. That said, pretty disheartening that you have to correct something that's brand spanking new and should have been inspected and measured correctly when it was manufactured? And measured with a lot better tool collection than the likes of us DIYers get by with! Another total assumption on my part but I would hope i'm right on that one......
lvporschepilot 02-01-2019 10:50 AM
Yeah sucks that some aren’t just right when new, but when a factory is cranking out multiple hundred I’ll take 3-4% with some issues all day.
Tippy 02-01-2019 12:16 PM
China has the same capabilities as us in the engineering, machining, and manufacturing departments, it's just it seems they fail at adopting quality control.
I used to be in quality and dealt with Chinese suppliers daily.
Mark Henry 02-02-2019 05:37 AM
As a builder I doubt if they're doing special custom runs of rods. What I would guess is they're buying rough forgings of a rod that's close and having them machined to their specs.
I wouldn't be at all surprised if they're the same rough forgings as SCAT or CB Performance VW rods.
If you were to go this route I'd at least invest in ARP rod bolts.
The 996 3.4 rod is very close to one of the chevy 5.7" rods, so close only the pin size is different.
lvporschepilot 02-02-2019 09:51 AM
Depends on the factory. There is such a wide gap in factory quality out there it’s almost impossible to know unless you physically go and check out their operations, or someone is kind enough to tell you who is good, which is usually pretty well-kept information.
Trackrash 02-02-2019 10:26 AM
How much do these weigh?
lvporschepilot 02-02-2019 01:39 PM
I was told they are some 150g lighter each than stock rods.
Tippy 02-04-2019 06:40 AM
True. The more I work around the Chinese, the more I feel comfortable using their stuff; as long as you can verify pedigree.
Schmierung 02-08-2019 09:51 AM
As dimensional check by Polo Motors, these are 'spot on'. Penetrant testing to follow.
'76 911S 3.0 04-23-2020 03:40 PM
Apparently they sell rockers now too...
https://www.cxracing.com/engine-connecting-rods-rockers-crankshaft/RRA-P010-SHAFTx12?sort=p.price&order=ASC
Trackrash 04-23-2020 03:49 PM
Originally Posted by '76 911S 3.0 (Post 10836590)
I'm not sure why they are calling these roller rockers, since there is no roller and they have a brass bushing.
Also some of the pics show wear on the contact area.:rolleyes:
winders 04-23-2020 07:02 PM
I would not risk a motor on these rods. Hell, proper fasteners cost more than these rods.
peterpullin 04-26-2020 07:00 AM
worth a test i think
out there there is lots of engines running this rods - only high output machines that need strong rods. if you look at the vw scene they use them as standard. i bought a set for my turbo. had three factory sets on the shelf. reworked, weighted and ready to go. i decided to use the chinese crap - no problem for thousands of miles.
there is the legend this is the same material pauter and carrilio use. same factory delivers the raw rod. then they are machined. in the states for pauter and carillio - for ping and pong in china.
they are succesfull as you can see in prices. in the beginning they were 399 to 550 a set - now they are between 700 and 1200 $ a set over here.
lots of hight output 996 turbos use these parts over here. if they fail it is usually not the „china crap“ ....
winders 04-26-2020 07:26 AM
You probably have a financial interest.....
You want to use them? Go right ahead. I wouldn’t touch them with a 10 meter pole. Worth’s test? No way....
mikedsilva 04-30-2020 04:39 AM
They look pretty decent...
anyone run any yet??
Mark Henry 04-30-2020 09:20 AM
I have a T4 914 engine in my '67 VW bug, 78mm X 102mm nickies/JE, EFI about 180hp so close to double stock HP. I have about 25K miles on this engine.
Uses common CB Performance made in china rods, less than $300 a set/4. A lot of VW aircooled have run these without issue for at least 30 years.
I have another big T4 engine on the bench, 2.3L, 80mmX 96mm and it has SCAT made in china rods. Scat uses the same rod cores in V8 engines.
I use a lot of Carrillo rods in my 996 builds, other than the label the rods look the same as the CB or SCAT H beam rod.
lvporschepilot 04-30-2020 12:46 PM
These 911 engines just aren't making massive power, certainly well under even what even the Chinese forged rods are capable of handling. Hot rod Ford/Chebby, turbo Nissan/Toyota/Honda motors are pumping FAR more power per cylinder than some hot rod 911 motor yet are using catalog Scat or 'name your manufacturer' Chinese rods ordered from Jegs, pumping 700bhp. As I stated earlier, I have two vintage racing clients running the el cheapo Chinese rods, zero failure to date. Some sizing issues were experienced with a couple, so as with anything, measure and check.
winders 04-30-2020 03:44 PM
When building a $45,000 engine, the cost of the Chinese rods versus Carrillo rods is nothing.
I am buying American made any time I can and avoiding Chinese made any time I can...
