-   -   engine stand yoke (http://forums.pelicanparts.com/911-engine-rebuilding-forum/774702-engine-stand-yoke.html)
CLEMMY 10-03-2013 08:09 AM
engine stand yoke
Why is it necessary to mount the yoke on the right side of the engine (passenger side)? is this a structural issue?
Heinz911 10-03-2013 08:48 AM
That is the side where the oil pump is mounted. If you would split the case with the wrong side mounted in the yoke, you would probably have an issue with the intermediate shaft being connected to the pump.
CLEMMY 10-03-2013 08:55 AM
I'm not planning to split the case. So if that's the only issue then I'm all set. Thanks for the quick reply.
