carrerarsr65
je pistons?
Can I run 10.5 on single plug street motor on 91 gas
Old 10-08-2013, 09:34 AM
Straight shooter
Lapkritis's Avatar
Need more info on the setup - intake, exhaust, etc
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 10-08-2013, 09:44 AM
Asked the same thing the other day, and was told to go with the 9,5's. Looked it up, and to quote Wayne from the "How to build and modify" -For 10:1 or higher compression dual spark is almost a requirement and cyllinders with 98mm or bigger bore typically benifit from dual spark"
Old 10-08-2013, 09:56 AM
