Always Be Fixing Cars
Harbor freight 750lb engine stand work with yoke?
Im using one of these for my alfa engine rebuild and its great, especially for $45 750 lb. Engine Stand
Has anyone used it for the 911 motor and trans? Id likely buy this yoke Thanks for you advice. This is for and engine clean and top end job i just started on today.
'91 964 C4 - New Daily '73 Alfa GTV - 90% done 50% to go '65 912 - Welding in process |
Brando
I built my turbo engine on one. Use the porsche tool to fix it to though( its made to work with it).
It's cheep but works fine.
Turbo powa! 1977 911s. it's cool |
I bought the ebay yoke you refer to. It's plenty strong and ok for the price but it does have some significant limitations: You must remove the engine mounted oil cooler before it will fit and there is no room to install the clutch & pressure plate. I also could not install the exhaust heat exchangers on my 3.2 with the engine mounted to this yoke.
I once borrowed a friend's HF stand. After about a week, I returned it. It's fine when stationary. However, the 3-pt wheels don't inspire much confidence when rolling it. YMMV.
I opted to buy the 4-caster version from a local O-Reillys for about $65.00 and the pseudo-Porsche engine mount from ebay. Sherwood |
911 2.2 T targa
Next to the stability, a four wheeled U-shape stand provides more room for an oil pan/tray
I put a Ford FE big-block on one of those HF stands once, and it flexed so much under the weight that I didn't even unhook it from the hoist - I jacked it back up and bought another stand, this time a 1200 lb stand with a U-shaped base. That engine didn't quite weigh 750lbs since it was stripped down a bit, but it was HEAVY. Probably would be OK for lighter engines but the 1200 lb stand was something like an extra $20 or $30. I gave the HF one to a friend who works on VWs.
I have had the same experience as TT Oversteer with the ebay yoke. I did do some creative grinding on the yoke so that I could get the exhaust heat exhangers and crossover tubes removed, but the oil cooler needed to be removed, and the flywheel interfered pretty badly, it needed to be removed as well if you wanted to rotate the engine while on the stand.
1982 911 SC - 3.2, 17" 993 wheels, 993 interior, big red brakes. 1966 Corvair Sedan - 16" Superlight wheels, LED taillights, Euro H4 headlights. |
I bought a 1200lb stand from Northern Tool. They didn't have any in back so I asked if I would get a discount on the floor model. 20% off and I didn't have to assemble it :-)
Todd
'81 SC |
Thanks for the feedback guys. I'm more than happy to upgrade the engine stand, its peanuts compared to the Yoke. Yokely speaking, what is "the Cadillac" which allows full access/rotation and a minimum parts removal? I presumed the ebay was just a no name version of this with the same functionality, no? http://www.pelicanparts.com/catalog/shopcart/TOOL/POR_TOOL_WTD070_pg23.htm
Since this is my first engine drop (started disconnecting last night in fact) - would the sequence be: Drop motor onto my ATV jack Remove tranny Remove engine oil cooler if req due to ebay stand Remove heat exchangers Mount Yoke Pick motor by yoke onto stand
Other guys have more experience than I, but my $.02:
I'm using the HF model now. If you're not planning on needing to move it around too much, it's fine. I got the more expensive yoke and it's a work of art. Another thing to consider if you get the u-shaped stand is what method of lifting from ATV jack to stand you are going to use. I had an old heavy duty stand that had a base that was too wide to move into the engine hoist legs.
Since the P201 adapter clones must work on a variety of engine stands, the adapter arm that allows the engine to rotate and lock is often supplied blank.
If the goal is to rotate and lock the engine in various positions (you do), you may have to drill holes in the adapter yoke to match the stop pin holes in your engine stand. Sherwood |
I can't see the obvious difference between P201 and the ebay Yoke in the pictures. Is it correct that the ebay yoke can in fact be modified to allow the motor to rotate freely? I'm not afraid of my angle grinder and its literally 1/3rd the cost of the P201...
2 - The P201 yoke has a very thick and specially shaped flange where it attaches to the engine. This spaces the yoke away from the engine slightly and allows clearance in several key areas. The ebay yoke is just a flat piece of 1/4" (or so) steel for the flange. Keep in mind you can probably recoup a lot of the cost of the P201 if you resell it after you're done. I knew that I'd never be able to talk myself into selling it, and I was willing to live with the limitations of the ebay yoke, so I went that way.
A separate issue is whether the eBay yoke has holes drilled peripherally that will match the holes in your engine stand to lock it in position. My yoke was undrilled and thus had to drill holes accordingly. If already drilled, compare the location of the yoke hole(s) with those on the engine stand. The factory P201 yoke is designed to fit into a compatible engine stand or bench mount. Is yours compatible? Sherwood |
Keep in mind the diameter of the yoke where it slides into carrier might not fit the cheaper stands as well.
Todd
'81 SC |
I checked and the ebay yoke has the same OD as the HF stand. Mr Project - you mentioned flywheel conflicts, what about the stock exhaust on a 3.2?
Straight shooter
I used a similar combo - the 3 spoke yoke and a HF stand but shaped with a footprint like an 'H'. The oil tray fit perfectly underneath. Stand and yoke worked great. You do need to plan to drill holes in the yoke for your stop pin on the stand. Take care not to lean on the engine as I would be more concerned about threads pulling from your engine case than the yoke or stand.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
![]() For the stock 3.2l exhaust, I was able to grind a relief in the flange of the ebay yoke to get enough clearance to remove the crossover tube. That was the worst of it. I don't have a good picture of the chunk I had to grind out of the yoke, I'll get one later if I think of it.
I still have one for sale, built to hold 930 turbo, all welded boxed steel and large aluminum drip pan and castors. Comes with engine yoke holder (not yoke). $285.00 Mark
608-493-3011, Madison WI ![]()
I am currently just finishing up on a rebuild of a 3.6 from a 993. I am using the four wheeled engine stand from HF. I did look at the lighter three wheeled stand and passed on it because of concerns about stability. Now that I have the full weight of a fully dressed engine on the heavier stand, I can say that I definitely made the better choice. Even on four wheels, you have to pay attention to how you turn the engine over. I usually grab an attached component like one of the heat exchangers and lift up to rotate the engine in the stand.
A fully dressed 3.6 motor probably weighs right around 500 pounds, and I believe this stand is fine for that. Not certain if I would hand a 700 pound big block off the same stand! I elected to purchase the P201 yoke from Pelican and do not regret that decision either. The yoke has sufficient standoff room to allow you to attache the flywheel and clutch to the motor. And, there are no interference issues with any of the accessories on the 3.6 motor. The yoke is expensive, but in the scheme of things is cheap insurance. The yoke also has has a hole drilled through it that matches exactly the HF yoke receiver. The P201 yoke is long and protrudes out of the rear of the HF stand's head. In retrospect, I should have drilled holes in the end of the P201 to insert a rotation bar which would have made rotating the engine in the stand very easy. One weak point on the HF engine stand are the steel clips used to hold the fixed wheels in place on the stands axle stubs. This clips have snapped off my stand twice resulting in a wheel falling off the stand. Fortunately, this occurred early on when all I had mounted was the engine case which does not weigh much. Since then, I have kept an eye of this feature and have tapped with a hammer on occasion to make certain that they are firmly seated. I've attached a photo of the stand and yoke I'm using.
Ernie 98 993 C2S - Arena Red/Beige 76 914/6 3.2 Conversion - Estorill Blue/Coral Red |
