-   -   tach wires (http://forums.pelicanparts.com/911-engine-rebuilding-forum/775387-tach-wires.html)
Kremer#2 10-07-2013 09:31 PM
tach wires
If the brown wire from the Xdi is for the tach, what color is the 911sc tach wire? I have an adaptor from MSD to use in between.
fred cook 10-08-2013 07:52 AM
MSD in SC
I used the black wire from the left end of the MSD6A unit for the tach source. It plugged into the front center spot on the CDI master plug. I did not need an adaptor. Hope this helps!
