-   -   Stomski Piston Circlip Injector Size? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/778024-stomski-piston-circlip-injector-size.html)
Gordo2 10-23-2013 08:34 PM
Folks,
I ordered a set of JE 3.2L 9.5:1 (part 274640) pistons for my engine. Looking at purchasing the Stomski Circlip Injector tool to aid circlip installation but want to confirm the tool size before I order it.
The JE site shows that the wrist pin for this piston is 22.9870mm, so I assume I need the 23mm Stomski Injector.
Can anyone confirm this?
Thanks,
Gordo
Flat6pac 10-24-2013 04:30 AM
3.0 and before are 22mm
3.2, 3.3, not short stroke 3.2, is 23mm wrist pins
Bruce
euro911sc 10-24-2013 06:59 AM
I just use a pair of needle nose pliers with a small groove filed in the tips to hold the circlip...
Flat6pac 10-24-2013 09:05 AM
I got the pliers BUT the JE clips are a bear with just pliers and the Stompski tool is a nice piece to work with.
Bruce
Gordo2 10-24-2013 07:11 PM
Ordered the 23mm Stomski Circlip Injector.
Gordo
