Are my pistons and cylinders junk?
78sc
apart for a valve job and resealing and general freshening without splitting the case (still hoping not to)
First bummer was finding that I had Alusil P&Cs
and then I found 24 Dilaver studs ( 24!)
now this:
Just pulled the #6 piston and measured the top land and I can slip an .008" feeler gauge in there ( at 6:00 if the wrist pin is at 3 an 9:00 )
.006 at 12:00
I haven't measured the others yet... it's about dinner time.
Old 10-31-2013, 06:21 PM
How many miles on the engine? It looks like your pistons are worn out. You could look for a used set of Nikasil or bite the bullet and put in a new set of Euro's.
-Andy
Old 10-31-2013, 09:28 PM
the odometer shows 193,000miles 1978sc
but the car came with zero history.
Clearly the engine has been open b4 since the headstuds are dilaver.
what would a euro set give me?
Old 10-31-2013, 09:40 PM
9.8 compression, high test gas and a fuel injection head that needs to be replaced with the matching euro.
A good set of nikisil 8.5 or 9.3 cr will get you on the road.
Bruce
Old 11-01-2013, 04:15 AM
Bruce
The Euro pistons will give you about 9.3 actual compression ratio. I don't understand why you would need a different injection head. My race engine went from 9.3 pistons to 9.8 pistons and I didn't even need to rejet the carbs.
-Andy
Old 11-01-2013, 06:56 PM
