Are my pistons and cylinders junk?
78sc
apart for a valve job and resealing and general freshening without splitting the case (still hoping not to) First bummer was finding that I had Alusil P&Cs and then I found 24 Dilaver studs ( 24!) now this: Just pulled the #6 piston and measured the top land and I can slip an .008" feeler gauge in there ( at 6:00 if the wrist pin is at 3 an 9:00 ) .006 at 12:00 I haven't measured the others yet... it's about dinner time. |
How many miles on the engine? It looks like your pistons are worn out. You could look for a used set of Nikasil or bite the bullet and put in a new set of Euro's.
-Andy
72 Carrera RS replica, Spec 911 racer |
the odometer shows 193,000miles 1978sc
but the car came with zero history. Clearly the engine has been open b4 since the headstuds are dilaver. what would a euro set give me? |
9.8 compression, high test gas and a fuel injection head that needs to be replaced with the matching euro.
A good set of nikisil 8.5 or 9.3 cr will get you on the road. Bruce |
-Andy
