'82 S/C 3 liter build
Stock '82 S/C. Motor I believe 9.3 comp. want to put PMO carbs @ wonder which cams will work best. Will be street car, daily driver . I plan to take at least 400 pounds off the car, just looking for a little more pep. Any thoughts out there? Norm
About the best you can do without changing pistons is installing C-2 cams.
Might consider 78/79 big port heads. Bruce |
| All times are GMT -8. The time now is 05:19 AM. |
