CIS fuel head and injector question
Subject is an 87 930 that screams at WOT, but feels like it's missing a cylinder at idle and light to medium throttle. I flow tested the injectors in the car. The outputs were all dead-on identical, but #4 had a noticeably different spray pattern. Not nearly as conical and atomized as the other 5.
Here's where it gets interesting.... I swapped it with #5 and the issue did not follow the injector, it stayed on #4. My question is, if the output volume is identical, what in the fuel head could cause a different spray pattern? If the pressure was different in that line, I would expect the total output to be different. I repeated the test 3 times with the same results. Thanks for your thoughts. Steve |
sounds like a line issue. ive heard of that happening. the metal injector line gets clogged, pressure decreases and then this happens. could be worth a shot. there is an adjustment at the FD for the individual injector outputs.
| All times are GMT -8. The time now is 02:38 AM. |
