earthtorobots.com
request: dipstick tube pics
Hm. Maybe poorly worded title but that's what I need.
Recently purchased my first 911, a 69 T, and I'm slowly finding all the little frankensteins it's picked up over the years. Is this oil filler neck correct for my car? If so, isn't there supposed to be a little tube in there to hold the dipstick? Might have to weld a piece in but in the meantime, if I'm trying to check my oil (car warmed level surface engine on) how far into the neck should I hold the dipstick to replicate where it'd sit if it had the tube I'm thinking it's supposed to have? much thanks josh
The proper neck should be readily available from a recycler.
Bruce |
Attached is a picture of a oil spout with dip stick for a 71 911T. I took the dip stick out a little so you could see. There is a tube that extends into the oil tank and the dip stick goes into the tube. I am not sure if this is the same as that for a 69T, but I suspect it is similar.
![]() As flat6 said I image that it is readily available if your's is broken. Bob |
earthtorobots.com
awesome thanks fellas I'll swing by EASY. in the meantime, any pics from the top of the neck so I can see how far down the dipstick sits when checking it?
Vintage Owner
Dip stick
The ring sits just underneath the cap, with just a bit of clearance. You'll be close enough just eyeballing it, but I wonder what happened to the original tube.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Dip Stick
If you mean check the oil level, you can't. The stick is straight and bends as it goes down the tube. So unless you could do the geometry, it would be near impossible to figure out where it ends up to get an accurate reading using a straight dip stick. As long as it is close, the oil level gage reading is about ok and the oil pressure is ok, you will be fine until you get the proper oil neck. I can't imagine that it is expensive.
Do you even have a dip stick? I have heard of folks missing the tube and having the dip stick end up in the oil tank. Bob |
My computer doesnt recognize my camera so send me an e mail and I ll show you what I have from the parts bin that can be yours..
Bruce flat6pacnc@aol.com |
Uncertifiable!!!
See post #21 in
Oil Tank question It may be of some help although this is an '86. Let me know if you need any measurements. Cheers.....
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
earthtorobots.com
The later uses a 930 part number dipstick. The correct dipdtick is pictured above.
Bruce |
