-   -   89 Carrera Cylinders (http://forums.pelicanparts.com/911-engine-rebuilding-forum/781318-89-carrera-cylinders.html)
bcheney 11-12-2013 06:36 PM
Where some cars built with Alusils and others with Nikasils? Are there stampings that clearly tell you what type you have? My car is an 89 Targa with approx 192K on the clock and I may now be faced with a rebuild because of a suspected noise that could be connecting rod bearing related. Just wondering if P&C's could typically be re-used after inspection, cleaning and honing.
AlfonsoR 11-12-2013 08:39 PM
You can have either. Read this thread and post questions. http://forums.pelicanparts.com/911-engine-rebuilding-forum/453063-nikasil-alusil.html
bcheney 11-17-2013 04:39 PM
Nikasil Alusil
So it sounds like 11 fins = Nikasil if you have a 3.2 engine??
Flat6pac 11-17-2013 04:48 PM
3.0 has the same count too.
2.7 can be either way because Mahle also made alucil cylinders too.
Bruce
AlfonsoR 11-17-2013 08:32 PM
That's what I got out of it too, however, some additional clues are, I think...
The alusils should have a brighter finish on the outside. The Niks should be dull (typical aluminum-like surface corrosion I believe) if they have seen some miles
Also, not a sure thing, but the Mahle nikasil castings seem to have some characteristic casting marks.
KTL 11-19-2013 09:16 AM
Be they Nikasil or Alusil both can be reused. Not hard at all to clean them up, inspect & measure.
Nikasil seems to be more durable over time and the other benefit to Nikasil is using alternate pistons besides original Mahle. You can use JE, CP, Omega/Accralite, Wossner, Cosworth......
