-   -   zenith enrichment circuit delete (http://forums.pelicanparts.com/911-engine-rebuilding-forum/781648-zenith-enrichment-circuit-delete.html)
speedo 11-14-2013 05:01 PM
Carbs are rebuilt and on the engine. I could use a link that describes the process of deleting the enrichment circuit with some pics. Like to do this before I re-install the engine. Gracias.
Speedo
E Sully 11-15-2013 01:59 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/239660-zenith-40-enrichment-circut-bypass.html
http://forums.pelicanparts.com/porsche-911-technical-forum/738700-zenith-auxiliary-enrichment-removal-procedure-help.html
speedo 11-15-2013 07:26 PM
This helps...
But I could use a further primer that shows all the ports that need to be addressed. Some claim to just cut and pinch the lines, some clip and JB weld, and some tap and plug.
Speedo
