BOSCH injection red tap reference
Hello
I am looking for informations (supliers, pictures) about the red tap of mechanical injection. http://forums.pelicanparts.com/uploa...1335814423.jpg Thanks in advance Best Manu |
The Red Cap for the RSR pump is still available from Bosch. Part # 0 457 104 001
The problem is the metal threaded pipe is NLA. You can find some used ones off the early Mercedes MFI pumps. The photos below are not early MB pumps! http://forums.pelicanparts.com/uploa...1384903880.jpg http://forums.pelicanparts.com/uploa...1384903906.jpg http://forums.pelicanparts.com/uploa...1384903929.jpg |
Supertec is selling a kit that seals the pump (removes oil supply) that includes a breather that bolts on rather than requiring a hole to be drilled in the housing.
This is important for two reasons. First you can install the kit without removing the pump from the engine and second you can put the pump back to stock without any tel-tail signs. http://forums.pelicanparts.com/uploa...1384960126.jpg http://forums.pelicanparts.com/uploa...1384960182.jpg http://forums.pelicanparts.com/uploa...1384960256.jpg http://forums.pelicanparts.com/uploa...1384973470.jpg |
Thank a lot Mark, Henry
Best |
| All times are GMT -8. The time now is 10:35 AM. |
