Case through bolts
I think I have a leaking upper case through bolt on my 993tt motor. Does anyone know if it is possible to replace the seals and re-torque the bolts w/o taking the cylinders off? My guess is that it is not.
Thanks Ken |
Cylinders are mostly in the way. It's the heads that actually get in the way the most.
http://forums.pelicanparts.com/uploa...1385487966.jpg Some good pictures of thru bolt proximity to cylinders and the head in this topic http://forums.pelicanparts.com/911-engine-rebuilding-forum/452985-your-opinion-wanted-green-bolt-through-viton-o-rings-rtv.html |
Thanks Kevin
BTDT, many many many times. |
Thanks Steve
| All times are GMT -8. The time now is 05:11 AM. |
