-   -   Got a few questions before my parts order (http://forums.pelicanparts.com/911-engine-rebuilding-forum/785426-got-few-questions-before-my-parts-order.html)
ertech 12-04-2013 08:26 PM
me again
1-Oil Pressure Relief Piston & Spring ??do I just change the spring?
2-Oil Line Restrictors ? what do I need to do?Just the restricors or special line
4-#8 bearing do you guys replace them usally?
thanks
BTW car is an 89 911 turbo
keynsham1 12-05-2013 12:20 AM
I just replace the springs. No need to replace the pistons unless they show signs of damage.
I plan to change just the oil line restrictors. I have new oil lines as they are cheap and apparently are prone to leaks.
Again, if the #8 bearing is not worn, scored, marked, etc, reuse it.
