-   -   Testing Spark Plug Connectors (http://forums.pelicanparts.com/911-engine-rebuilding-forum/785709-testing-spark-plug-connectors.html)
Tom Oxner 12-06-2013 07:16 AM
Is there a relatively easy way to check spark plug connectors to determine if they are good. Thanks,
Tom
Walt Fricke 12-07-2013 08:43 PM
Use a VOM. First for continuity, and then for ohms.
You'll see if any are much different than others easily enough. These connectors have a long cylinder of what looks like graphite inside, with spring tension keeping its ends pressed against metal bits which stick through the ends. If it doesn't make good connection at both ends after a long hard life, it can stop working properly.
tom1394racing 12-09-2013 06:39 AM
I snap a good spark plug into one end and measure resistance from the screw end of the connector to the spark plug. Good ones measure between 1 and 3 K-Ohms.
kwikt 911 12-09-2013 05:01 PM
I check it for resistance while thumping it with my finger tip. some show a wide resistance range while others stay stable.
