-   -   Engine Compression Numbers (http://forums.pelicanparts.com/911-engine-rebuilding-forum/785981-engine-compression-numbers.html)
Midlifecrisis42 12-08-2013 01:19 AM
The guys working on the resto of my 1970 T got these compression numbers from my engine,
1 - 90
2 - 90
3 - 90
4 - 130
5 - 90
6 - 90
They also said
Scoping the bores shows cleaner edges to the piston tops meaning oil ring issues. the numbers say compression rings as well.
I would say this motor needs a "Top-End" meaning, everything from the rings out (rings, valve guides, valves, rebuild carbs etc.)
Can anyone recommend a thread I can read so I can learn more about this as I'm a newbie. I don't doubt the advice given is 100% correct as I trust them completely (well known in Porsche circles) I would just like to learn more and broaden my understanding of the topic. I would also like to understand about the compression numbers.
fred cook 12-08-2013 03:59 AM
Engine info
Buy a copy of Wayne's 911 engine rebuild book. It contains just about anything you would need to know about these engines. If I remember correctly, any compression variation from cylinder to cylinder of more than about 5% should be checked out. The 130 number is probably closer to what they all should be.
Midlifecrisis42 12-08-2013 11:56 PM
Thanks Fred, I will ask the wife to get it for me for Christmas!
JJ 911SC 12-09-2013 02:00 AM
No, you get the book and ask the wife for the Top End parts for Xmas :D
HawgRyder 12-09-2013 12:04 PM
This is a test....just how far can a man push the envelope in asking his wife for parts for the Porsche?
We are standing by! ..... LOL
Bob
