-   -   Nikasil Replating of Alusil Cylinders (http://forums.pelicanparts.com/911-engine-rebuilding-forum/787869-nikasil-replating-alusil-cylinders.html)
pooder 12-19-2013 09:02 AM
I am planning a 3.4 conversion of my 3.2 which has Alusil cylinders. I am inclined to re-bore my 95mm cylinders to 98mm and replate with Nikasil for use with JE pistons. I have spoken with EBS and they believe that this is a very viable option compared to buying new Mahles or Nickies. I welcome any advice on this. Thanks
Peter
IXjamesXI 12-19-2013 09:16 AM
Do some more hunting on the forum and you will find that many have done it with success.. it really seems economical compared to your alternatives. I just had it done myself.. I haven't had a chance to check the piston to cylinder clearances yet, but the work looks first rate.. my cylinders look brand new and the JE pistons look impressive too.
pooder 12-19-2013 09:25 AM
Thanks,
Who did you use for this process? I have spoken with EBS.
Henry Schmidt 12-19-2013 10:26 AM
The process of plating Alusil cylinder with Nikasil produces a nicer product than stock Nikasil cylinders.
The reason is the high silicon content of the Alusil aluminum is more stable and in turn expands less. The key of course is to use a company with experience in the process.
EBS is a great source for this product. In some cases, they even have an exchange product on the shelf and a reasonable price.
IXjamesXI 12-19-2013 10:47 AM
I used EBS... they are nice to deal with. I was having 95mm SC Alusil cores re-plated in Nikasil (to accommodate new JE's) and then changed plans midstream when I came across some Mahle Carerra cyls and got bitten by the 3.2SS bug. They worked with me and gave me a nice credit for my cores.. do it!
r-mm 12-19-2013 12:32 PM
In these instances, what does one do about the motronic? Get a custom chip from you preferred supplier?
Can someone hint at the all-in price of this conversion?
pooder 12-19-2013 02:59 PM
Thanks to all for your input.
peppy 12-19-2013 05:35 PM
I also used EBS to do my cylinders. I have no complaints.
peppy 12-19-2013 05:36 PM
The car will run with the stock chip.
$8000
pooder 12-19-2013 07:28 PM
R-mm: In my case this conversion will also include head work (valve guides and seats), improved exhaust with SSI's and sport muffler, cam regrind to 964 profile and dual plug modification. A custom chip is required for all of this. This conversion is designed to maximize performance w/o compromise in reliability. As others on this forum will attest, a 3.4 conversion opens the potential of improved performance and this temptation can make the story more complicated than just P+C's.
r-mm 12-19-2013 08:23 PM
I was going to say that 8k is a more than double brand new euro high comp 3.2 p&c. When this is said to be economical, is that in comparison to? Does the 3.4 overbore require twin plugging?
peppy 12-20-2013 04:23 AM
Sorry I was assuming head work and a complete rebuild.
I also did cams when I did mine.
I do not have twin plugs on my car.
r-mm 12-20-2013 06:21 AM
Can someone give us an idea what the cost for overboring, re-plating and JE pistons & rings would be?
pooder 12-20-2013 06:58 AM
I was quoted a price of $900 for over-boring and Nikasil plating or the set of six cylinders. The JE pistons are going to be approximately about $1000 from our host.
r-mm 12-20-2013 07:12 AM
Very good deal indeed. Mine were in spec during my top end, but ill think about this in another 100k miles...
