-   -   Crankshaft - Rod Journal diameter and width: 2.4/2.7 vs SC (http://forums.pelicanparts.com/911-engine-rebuilding-forum/788533-crankshaft-rod-journal-diameter-width-2-4-2-7-vs-sc.html)
blue72s 12-23-2013 03:48 PM
While I understand why Porsche had to reduce the rod journal diameter from 57mm to 52mm to achieve the 70.4mm stroke (otherwise wouldn't be possible) for 2.4 models but why did they also widen the journal width from 22mm to 24mm (thinning the webs from 7mm to 6mm in the process), and then go back to 22mm width and 7mm webs again in 1978?
Can 66mm cranks be machined to 70.4mm stroke with SC spec rod journals? If so, why didn't the factory racing department do this when they experienced vibration problems with the 2.5ST long-stroke and the 2.8RSR?
blue72s 12-26-2013 05:01 AM
EDIT!!!!
Sorry, I had got the specs from Wayne's book and there's a mistake there. The SC rod journals are not 52mm dia x 22mm width.
Here is the correct version:
Diameter of SC journals: 53mm
SC rod width at big-end: 22.6mm
So, the thickness of SC webs are about half-way between the 66mm and 2.4/2.7 cranks.
If I'm calculating right, the 66mm crank CANNOT be machined to SC rod journal spec, because it is short of shaft material by 0.2mm.
BURN-BROS 12-26-2013 10:39 AM
SC rod journal width is 22mm. The 66mm rod journal can be ground down to diameter and width of the 3.0 liter journal. We do it all the time.
Henry Schmidt 12-26-2013 11:00 AM
The conversion became more viable when a production GT3 rod became available.
Previously we needed a custom rod to suit this conversion.
blue72s 12-26-2013 12:50 PM
Thanks.
From Frere's book:
3.3 Turbo and 3.2 Carrera (74.4mm stroke)
Rod journal 21.8mm width x 55mm dia.
3.0 SC (70.4mm stroke)
Rod journal 22.6mm width x 53mm dia.
Another question:
If the GT3 rod journal is 21.8 width x 53mm dia, then the surface bearing area is smaller than all its predecessors (2.0 to 3.2 Carrera).
Why's that?
BURN-BROS 12-27-2013 09:48 AM
The GT3 rod big end width is 21.9mm
The SC rod big end width is 21.8
The SC journal width is 22mm
The 2.0 liter journal width is 22.1mm
The journal diameter of 53mm came about around the 936/956 engines. The width was settled with the 9 bolt 935 engines/ 911SC 3 liter
Porsche used this dimension on all the competition cars...935,962,GT1,GT3.
blue72s 12-27-2013 01:40 PM
3.3 Turbo
http://forums.pelicanparts.com/uploa...1388180283.jpg
3.0 SC
http://forums.pelicanparts.com/uploa...1388180315.jpg
BURN-BROS 12-27-2013 03:16 PM
It's a typo. All the measurements I gave you came from actual parts in the shop.....
http://forums.pelicanparts.com/uploa...1388186095.jpg
blue72s 12-28-2013 08:52 AM
Thanks for the clarification.
blue72s 12-28-2013 09:54 AM
What is the radius of the fillets on the GT3 rod journals? (So, I'd know what is the maximum stroke length can be achieved with the 66mm crank)
BURN-BROS 12-28-2013 12:12 PM
I do not know that dim.
All you will be able to get is a 2mm offset grind...maybe. So 4mm of additional stroke max would be the result. 69mm stroke may be all you could do conservatively. Your crank grinder would have to tell you what he would be comfortable doing.
