-   -   Leak Down Test TDC question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/788865-leak-down-test-tdc-question.html)
cgfen 12-26-2013 08:50 AM
Lot's of thread son leak down tests, but none answer this question.
If I start @ TDC firing stroke for #1, are any other cylinders also @ TDC firing?
If so, which ones?
Real question = What is the most efficient way to test all cylinders with minimal crank rotation?
I'm thinking this is the "best" way???
so if firing order = 1-6-2-4-3-5......
  • find TDC firing #1 and test
  • rotate 120 degrees to #6 and test
  • rotate 120 degrees to #2 and test
  • ..... through to # 5?
I guess I'm asking if;
more than one cylinder can be tested without rotation
or
does every 120 degrees rotation after #1 TDC = TDC firing on the "next" cylinder.
Thank you
Craig
cgarr 12-26-2013 09:00 AM
You thinking maybe BDC power stroke? I like to bring each up to TDC most times if you have any cylinder scoring and want to check for that I would think TDC would be best. Lock the crank down.
