2.2E to 2.4E - MFI Upgrade required too?
I've got a 2.2E MFI engine that I will be rebuilding and happen to have a 2.4 crank and rods. I understand that I can use these and get around 9.6:1 compression which is probably on the edge. The question is around the stock MFI set-up. With the increase in displacement and power will the pump need to be modified or somehow recalibrated? Just wondering.
Matt,
You should have the pump recalibrated Philippe |
| All times are GMT -8. The time now is 05:27 AM. |
