-   -   main bearing surface question? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/791566-main-bearing-surface-question.html)
ertech 01-13-2014 09:12 AM
Hi guys does this look ok?what is the best way o remove this oil deposit?
Erickhttp://forums.pelicanparts.com/uploa...1389633114.jpg
brighton911 01-13-2014 11:58 AM
I had the same thing on two saddles, I called it staining. Here is the link:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/789973-possible-main-bearing-issue.html
Consensus was: clean it with brake cleaner or similar and move on.
