Unknown Part
I am just finishing a top end rebuilt of an '87 3.2. Wayne's book is a bit sparse towards the end. I did take quite a few pictures but this part seems to have escaped the camera. Does anyone know where it goes?
Thank you in advance. Bill
I believe it supports the spark plug wire bundle on the left. if its a 6mm hole so it bolts to the shroud bolt to the rear by #1 runner.
If the hole is an 8mm then it bolts to the top right rear nut on the valve cover and supports the spark plug wire harness after it comes out from under the A/C support and turns forward. Bruce |
