Need Valve Guides???
I need some input of the visual of the following valv/valve guides. I realize this is only a visual...............but a quick story of the car: I purchased it in July 2013 and the PO told me that his PO (Porsche mechanic) had overhauled the engine to some extent, but no paper trail to back it up (BTW, the car has 191k). The engine looks is very clean bottom and top. When I pulled the intake manifold to replace the fuel lines, I took a peak at the intake valves and notice that, in particular one valve was leaking oil, which appeared from the guide:eek: Now, the others also have some residue, but I believe the oil is from the over-filling the tank. The valves and guides do not appear as part of a 199k mile engine, but I could be wrong.
Calling all Pros: What are your professional opinions on this? http://forums.pelicanparts.com/uploa...1390615883.jpg http://forums.pelicanparts.com/uploa...1390615947.jpg http://forums.pelicanparts.com/uploa...1390616019.jpg |
ON your third pic it look something drop beside the valve.
It looks like the valves and guides have been redone. The oil could be from over filling. I would make sure the oil level is correct and then drive the car. After it is up to temperature, check to see if it smokes on acceleration or deceleration, giving you an idea if the guides are ok. Do a compression and or leak down test. This will help see if the rings and valves are seating well.
Thanx Sully, I keep the tank at mid level, so I don't think it's that. The compression was about 170 all around, but have not done a lead down. I occasionally get the morning cold start puff of smoke, but none on decel and accel, so that's good. Note, the PO had it for 10 years and only put 8k miles on it, so the car sat in storage for a while. Anything I can add to maybe loosen up the rings if they are stuck?
Just drive it and monitor oil consumption for now. The guides look new so maybe just a bad stem seal.
There is some consensus that squirting Marvel Mystery Oil into each spark plug hole and then allowing the oil to set for several days will free up rings. Ideally, you should have the motor on the stand so that the P&C's are vertical and then roll the motor over to TDC for one of the pistons Then flood the single piston with MMO and allow it so sit for several days. Then roll the motor over until the next piston reaches TDC and repeat the MMO exercise. Do the arithmetic and it will take you several weeks to treat each piston and its rings to the MMO treatment. |
Is it an easy task to remove/replace Valve Seals? Input would be greatly appreciated.
Serge |
So to answer your question, no |
^^^^^^ what cgarr says...listen to someone who knows what he is talking about...jmho...
That much oil from a guide at rest isn't possible. I would be more inclined to place my guess on oil leaking primarily past the piston rings when the engine has rested for awhile.
Anyone else have an opinion on this?
Serge |
My apologies- not sure what I was thinking when I posted it might be due to oil past the rings. That would also be nearly impossible due to gravity. I'm also in the stem seal boat for my guess. Perhaps the spring on the seal broke for that valve. It does happen although rare.
intake guides are way up out of the oil that collects at the bottom of the cam tower, so i doubt that much would come down the guide, even without a stem seal.
The seal could be replaced without removing the head.
The oil could be there from just sitting too long. Probably you need to drive it more. |
As clean as the intakes look, it has probably had the claimed work done. The discoloration of the interior (brown stain) could come from dye in the gas.
I've been following this thread for a while, since your picture of the puddle of oil on top of an inlet valve was intriguing. Since no plausible resolution has been offered up, here is my "non-professional" opinion.
First off, the oil had to appear AFTER an engine shutdown since that area is continuously washed down with an air/fuel mixture which should cleanse the area of any oil accumulation. Second, the oil that is present appears to be extremely clean with no discoloration. So, unless you had just changed your oil prior to removing your induction system, I question that what you are seeing is engine oil from your system. So, is there the possibility that you used some sort of petroleum solvent in the process of dismantling the induction system on the car? Is there a possibility that you somehow spilled some into that single port? Incidentally, the back side of the valves look pretty clean, and not what you might expect to see out of an engine with more than 100k miles on it. In the 911's I have owned, the valve guides were usually shot by about 80k miles. So my guess is that your car has had at least one if not more upper end refreshes and it appears that you may have had a refresh not to long ago. |
Earossi,
The oil that you see does not have many miles on it, and that is why it looks clean. Prior to taking the intake off, I did not use any solvents at all. Here is a shot of the Plenum when it was off, Nasty! The PO did state that the engine had been rebuilt (but no paperwork to prove it), and according to my calculations that I came up with, the engine appears to have approximately 10k miles on it. allhttp://forums.pelicanparts.com/uploa...1396884439.jpg Appreciate the feedback from all of you! Serge |
I couldn't find where you told us what engine this is? However, the last picture makes it look like a 3.2 intake?
Judging from the oil in that picture, I'd guess that is the source of a bit of oil in the intake port area. Why not just clean out those parts of the intake, plus whatever else you can get at conveniently between the air filter and the intake manifolds, wipe out the ports with a rag or towel, and call it good for the moment. I'm not hearing that you have signs of problems. Some puffs on startup are normal - perhaps a feature of a horizontal boxer motor? |
Yes, it is a 3.2 and the "PUFF" of smoke is random and I am not experiencing any issues with the car running, although there is a hint of burning oil smell through the exhaust (no smoke upon acce/decel. When I check the spark-plugs, I notice that the only slightly "Darker" one in color is this one that lives below the "Oily" puddled valve. Here is a pic of what the engine bay looks like now.http://forums.pelicanparts.com/uploa...1396912885.jpg
Could just be getting some oil in thru the intake? check the vent/vac system and make sure you have the restrictor (aka dog dick) at the line to the oil tank and its the correct way.
All I can say is, "Many thanks to all who have taken their time and effort in providing quality feedback"! And truly, this is fantastic place with great people!
Serge |
Something to add to this Dilemma - I have been hearing a sorta "Knocking" sound around the same area where the "leaky" valve resides (cylinder 5). It only exists at certain points in time and not an on going sound. Note: and it is not the valves for sure. I am beginning to think this maybe related? Would a broken valve spring be the culprit? And BTW, I am showing a slow loss of oil and burning through the exhaust.
I am planning to take the passenger side intake off to take a look at the leaky valve in question, and wanted to know if I can do anything that can point to maybe having a loose valve or guide? I am thinking of having a leak-down test done for once and for all. Thanx, Serge |
I am reviving this thread....
Over this weekend, my car was driving like a MO-FO, for which it felt like it was going to dump me on the side of the road. The idle was lower than usual, the car was shaking like it was running on one or two pistons.
I decided to look into it and first thing I noticed was that my intake manifold bolts were all loose..:eek:? Anyhow, while I had the intake off, I decided to take a peek at cylinder 5 and check on the previous oil leak that was there, and low-and-behold, it was there! This time though, I decided to open up the valve and taking a peek in there, and what did I see...the exhaust valve covered with some black soot! So experts, would it be wise to take the car over to my Wrench to have them assess the situation, or should I take a stab at performing something that might fix this? Opinions please?? FYI, after buttoning everything up, the car is now running like..a CAR!!! Thanx, Sergehttp://forums.pelicanparts.com/uploa...1403564697.jpg http://forums.pelicanparts.com/uploa...1403564727.jpg |
-Andy |
Any other suggestions?
Serge |
Are you sure that it's oil? Having any cold or hot start issues? 181k miles and original injectors could be getting sticky. Suck it out with a syringe and see how easily the "oil" lights on fire. ;) Injectors can be sent off and cleaned easily enough.
If it's oil, then definitely Italian tune-up followed by cold beverage. In that order only! |
nickd,
No hot or cold issues, although I do get "the oil smell" upon coming to a dead-stop, which I am associating this leak to, but I could be wrong. Spark-plugs are ok except this one, which has a little bit of oil around the thread. |
| All times are GMT -8. The time now is 11:01 PM. |
